Transmission Fluid
I heard back in the day one of the two is more acidic than the other. I don't remember which one it was. But I can tell you type "F" gave firmer shifts. This is why Ford switched fluids in the C6 circa 1977. To give them a softer, more cushy cushy shift. As to finding out what a PO put in....I would locate a local Lab that can analyze the existing fluid. As we have mentioned in previous threads when a tranny is built it's friction discs are soaked in whatever fluid is going to be filled in the tranny. Now the fluid can't be mixed or changed. Unless a total tear down and clean. Others on this Forum have tried it only to have their tranny (the friction discs) slip.
on
on
I don't see the logic in using anything other than type F in it. A shift kit wouldn't change that either.
I'm still trying to decide what I will use When I swap my AOD into the truck, I could use Mercon, since that's what it was designed to run, or I could use type F for firmer shifting and less slipping.
Fun fact. Mix Type F with Acetone 50/50 and you now have the world's best penetrating fluid.
66ford300
04-02-2018 10:05 PM
Corallis
04-30-2015 02:40 PM
leonharu
09-07-2004 04:42 AM
