Extended front brake lines
Old 05-02-2012, 09:03 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
what is the best brand, price and seller of extended brake lines?
97 f250 d60 swap with sd v codes and sky mfg 3" rsk
Old 05-02-2012, 11:26 AM
fordpride's Avatar
fordpride
fordpride is offline
I'm not sure but you could PM Evan ( brown falcon ) he just did this not that long ago. Here is his thread
https://www.ford-trucks.com/forums/1...dana-60-a.html
Old 05-02-2012, 12:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Crown Performance makes some awesome brake lines, BUT when I tried to run them on my truck, they weren't really even close to fitting at the calipers. The bend in the steel portion of the line was wrong and it hit the calipers and b/c of the way the caliper is cut, the block on the line wouldn't sit flat on the caliper. From what I can tell, all of our calipers are shaped/designed the same, so I'd beware of those lines on our trucks. They have a reputation for not fitting at all on the Broncos, F-150's, and F-250's.
I put those on the shelf and bought some Russel SS lines and they fit A LOT better. They are a little shorter than the Crown lines were, but they will actually bolt up.
Old 05-02-2012, 02:28 PM
BadDogPSD's Avatar
BadDogPSD
BadDogPSD is offline
I have the Crown on my truck and didn't have any issues... got them from Caryt @ CT Performance.
Old 05-02-2012, 02:34 PM
strokin'_tatsch
That's good to hear. They make awesome lines, I've just never gotten a set that fit on my truck.
Old 05-02-2012, 02:51 PM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Seems like the russell ones only go up to a 4" lift
With v codes and rsk I think im more than that
Old 05-02-2012, 11:17 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
On mine for now I'm running stock brake lines, but I ran the hard line down below the frame... later on I'm planning on getting stainless braded lines
Old 05-02-2012, 11:35 PM
BadDogPSD's Avatar
BadDogPSD
My truck is a 97, but my D60 is a 94. I originally had purchased Sky Jacker
extended brake lines but didn't like the way they tied into the junction box so I returned them & bought the set from Cary. Guess I got lucky!
Old 05-02-2012, 11:57 PM
Brown Falcon
I'm running a '94 D60 as well.
Just curious, are the lines then same for the same years F150's and Broncos? Or do you need to get F250 or F350 specific lines?
Also, what are the prices on the Russell and the Crown? Any links?
Old 05-03-2012, 09:11 AM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
I took my stock lines to a hydraulic shop and had them make new ones but only 6" longer.
It is way better, faster and you can customize the length to what you need.
Plus it is way cheaper than anybody else sells them for.
Jim, You know my truck it has the D60 and RSK with "V" codes also. The lines work great.
Old 05-03-2012, 09:15 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Awesome thanks neal ill get ahold of the hose man today
Old 05-03-2012, 09:17 AM
gbroehl1's Avatar
gbroehl1
gbroehl1 is offline
You have a "hose man"? Why does that not surprise me. Is that where you do your swim suit shopping as well?
Old 05-03-2012, 09:25 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Greg ur creepin and I dont appreciate it...
Industrial Hose & Supply, Inc. - Home
Even his shirts say "hose man" on them
Old 05-03-2012, 09:27 AM
gbroehl1's Avatar
gbroehl1
gbroehl1 is offline
Nah, just working from home again today and trying to pass the time while doing as little actual work as possible.
Old 05-03-2012, 10:59 AM
Brown Falcon
When I talked to the local hydraulic shop they said that they weren't allowed by law to do brake lines because of safety regulations...
Quick Reply: Extended front brake lines
