Changing the differential
If your Navigator has AdvanceTrac, putting a LS diff in there will probably play hell with it. Since you plan on getting a used one, also keep in mind that the 03-04 models had an issue with the clutch pads wearing out. I don't remember if the 05-06 had the same problem. So based on that, I'd rebuild the LS before installing it.
AdvanceTrac uses a number of sensors to monitor traction and then manages it by reducing engine output and/or applying the brakes at individual wheels as needed. With a LSD, I would expect some situations to arise where the AdvanceTrac would conflict with the LSD. I do not believe it was a factory option to get the two together. It's worth researching. If they were available together then I wouldn't worry about it. If not, then I'd stick with an open diff.
Thank you. I'd stick with the open diff then.
OR invest in a selectable locker, I think they're available for our application. You could shut off the AdvanceTrac and engage the locker when you need it, which I would expect to be pretty rare.
I'm getting the differential for free. So if I am pulling out a boat the AdvanceTrac would be better than LSD? I do not want to spend money on this project
The LS diff will pull with both wheels equally and I think give you better traction on a wet ramp.
How big a boat and how steep a ramp are you talking?
Is the ramp hard surface or loose sand/gravel?
I use a very steep ramp (I keep the liftgate open so I can see what is going on but I have to take the luggage out of the Navi or the luggage will slide out the back coming up the ramp). Just put it in 4L and don't even have to give it any gas and it just walks the boat and trailer right out.
Why don't you make a practice run and see how your current set up performs.
You might be right I am over thinking this. It wouldn't be the first time. I just don't like the idea to reduce wheel spin is to reduce power at the exact time I need power. Wouldn't turning off AdvanceTrac when pulling boat out be better since full power will be used to both rear tires? I would be the ******* that would have my vehicle totally submerged into the water
