I get EOTs of 231-233 pulling a load of 12k sometimes the ECTs are around 18-20 deg lower. Ambient temps in the 80s-90s. Most times the temps are within 10-15 deg. I have a 6.0 with a very mild tune and erg delete. Is this about what to expect? Generally I get this going up grades and it backs off some when I hit the summit. No puking. Oil cooler is OEM and has about 30k miles on it.
Thanks for the input. I do have the studs, blue spring, etc. It has a very mild tune, about 15 hp. Had to put it on when erg was deleted to keep CE light from coming on. It's been running fine except for HPOP problems,but needed to make sure.
