Chatter
Old 07-04-2014, 11:25 AM
jeffnick's Avatar
jeffnick
jeffnick is offline
Chatter
'05 E350 V10 limited slip 120,000 miles.
Lately I've been noticing a slight chatter when going around a corner after a stop. As soon as I straighten her out the chatter stops.
I have a buddy with a 2010 F150 and noticed the same thing happens to him.
Is it the rear end?
Is this something to worry about?
Is there a fix?
Old 07-04-2014, 03:42 PM
gman97005's Avatar
gman97005
gman97005 is offline
I would take it to a shop that specialises in rear differentials, definitely sounds like a posi-traction related issue..
Old 07-04-2014, 04:02 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Many posi units will chatter when you lift the inside rear wheel. You could moderate the chatter a bit with some limited slip additive, but that will make the gear oil more slippery and in theory cut down the locking effectiveness of the diff when you do need traction.
I had an Eaton posi installed in my '02 when it was new and it will occasionally chatter when lifting the inside wheel on wet pavement, but am not really concerned. It's due for a diff oil change and I might ask for a little bit of extra additive at that time. The Ford OEM trac lock and my Eaton are both clutch type units; there are smoother gear type units on the market, but they all have their downside.
I take my chattering as a sign that my posi is still working....
And then there are pure lockers which are much more abrupt in their action--basically the outside wheel in a turn unlocks and freewheels. The lockers will be much tougher in terms of drivetrain shock.
It really shouldn't hurt anything unless you perceive the chattering as causing violent shocks to the drivetrain.
Good luck,
George
Old 07-04-2014, 04:19 PM
gman97005's Avatar
gman97005
Before adding 1 drop of any additive to any rear differential, take it to a shop that specialises in rear differentials..
Old 07-05-2014, 05:28 PM
jeffnick's Avatar
jeffnick
jeffnick is offline
Thanks guys. I'll live with it a while, then decide what to do.
Excurvelle
02-18-2019 04:33 PM
yukgoon
06-29-2006 10:19 AM
1 Cajun
1999 to 2016 Super Duty
20
02-15-2006 02:35 PM
phoneman
03-21-2004 06:53 AM
99Ranger
1983 - 2012 Ranger & B-Series
09-29-2003 12:47 PM
Quick Reply: Chatter
