BossFan's '78 F250 build
#676
#677
#678
#680
Thanks Rich. That's just what I did.
Now that I can see under the truck better, it looks like there are leaks between the transmission and transfer case. The gasket is all torn. I just replaced that when I put them back in. What's the best way to stop this? Another gasket with silicone sealer this time? Any tips on sliding this back without having to drop it to the floor?
I wiped away the leak but the gasket is all torn here and there was gear oil dripping out
Same with this side
Same with this side
#681
Stabilizer is angled
Has to be rotated up to clear diff cover
Rich
i tried mocking up the steering stabilizer install 180 degree swap, using your first photo with the dual stabilizers. The stabilizer is too long to use the welded tab as a stop. I would have to put the u-bolts in front of the diff, and at an angle so they clear when the tie rod moves.
Looking at your second truck, the stabilizer bolts into the the same place as the shock I have the hole there, however I thing I would need a stabilizer that had one male and one female end. My stabilizer has to mail ends
Rich
#682
Rich
Rich
#684
The one on the bottom is shorter and I don't know if you can see there is a thread beneath it from the trans
I remove these by hand
The four studs that connect the transfer case to the back of the trans were loose. As in, I was able to remove them BY HAND! No wrench! Is there a correct way to put these in so the stud is tight? Should I try putting two nuts on them so I could tighten them into the trans?
unfortunately it looks like a thread came out of the one on the bottom when I took it out
#686
#688
OK. What I did in the interim was I replaced the stud, which uses 1/2 x 13 to go into the tranny case, and then 1/2 x 20 for the nut, with a 1" bolt (1/2 x 13). I was able to grab threads deeper in the tranny case, and was able to tighten the bolt. I am planning on pulling the motor later this summer (looking to do either a short-block swap or replace the 351W with a 460), so I will have the TC and transmission out then.
#689
