Split vs Open plenum design
Old Jun 16, 2014 | 08:38 AM
Turbo Dog's Avatar
Turbo Dog
What are the performance differences in the two differnt intake manifold designs? Why chose one over the other?
Old Jun 16, 2014 | 04:51 PM
xlt4wd90's Avatar
xlt4wd90
The split plenums are usually to optimize flow for lower rpm ranges, while the open plenums are usually for higher rpm ranges. There are many manifolds of both designs whose operating range overlap each other, depending on the design.
Old Jun 16, 2014 | 06:31 PM
Turbo Dog's Avatar
Turbo Dog
Thanks, that's what I was thinking but I wasn't sure. I think the split plenum is used to get a smaller plenum volume to allow more flow velocity at lower rates as compared to a big open plenum being able to flow more voume at higher rates.
My 460 came with a Weiand split plenum high rise manifold. That should make it a bit better for the street than an open plenum design.
I don't know what cam is in it and it has stock heads. I'm guessing the heads aren't ported because it was built using stock exhaust manifolds. It does have a nice dual exhaust.
jtindale
29
Jul 27, 2012 08:45 AM
TheNomad
Nov 11, 2008 11:03 AM
knite26
Dec 29, 2005 06:07 AM
76 F250 4X4
Nov 29, 2003 07:19 PM
AG4.0
Nov 13, 2003 04:30 PM
