Sponsored by: Halo Lifts
Old 11-19-2014, 01:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
What is the mpg of the 2.7???
Old 07-28-2014, 10:03 PM
ssls6's Avatar
ssls6
ssls6 is offline
Originally Posted by 2015er
I think the 2.7 for a 4x4 with an extended cab Lariat will get 19 city and 26 highway
The 3.5L eco for a 4x4 has a combined EPA of 17 mpg. A 700lb weight reduction and small 2.7L mill should put the combined at 21-22. With a tow rating of 8500lbs, not to shabby.
  #62
Old 07-29-2014, 02:19 AM
CGiron's Avatar
CGiron
CGiron is offline
The EPA test are not ready yet. It´s kind of "Buying the pig in the poke"
  #63
Old 07-29-2014, 05:33 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,229 Likes on 807 Posts
I wasn't aware that the tow ratings had been released. Did I overlook a post or a link?
Anyway, the ecodiesel will max out at around 9K plus and has already proven itself as a fuel sipper. With the Ram diesel having better MPG's and a possible tow rating advantage, the only thing going for the 2.7L is buy in cost and overall maintenance costs.
There are pros and cons on both sides of this coin, I just hope that Ford's stubbornness about a small diesel doesn't hurt them.
  #64
Old 07-29-2014, 07:31 AM
seventyseven250's Avatar
seventyseven250
seventyseven250 is online now
Tim, I think the full ratings have not yet been released, but one of the twitter links did show that the 2.7TT was rated "up to" 8500 lbs.
  #65
Old 07-29-2014, 09:45 AM
ssls6's Avatar
ssls6
ssls6 is offline
I read 8500lb somewhere, seventy-seven has added some clarity. I also read 2200lbs payload or that number sticks in my mind. If ford had redesigned the 3.5L to be an iron block, dual timing chains, etc...I would be real interested in it but as it stands, the 2.7 looks pretty nice. I think I could live with 8500lbs or 8000lbs but not much less.
Port fuel injectors along with the direct injectors would be a nice addition to the family. Several companies now use one or more port injectors to keep gunk at bay in direct injected engines.
  #66
Old 07-29-2014, 10:01 AM
03 SVT VERT's Avatar
03 SVT VERT
03 SVT VERT is offline
I'm curious if that 8500lb number is off a regular hitch now or if it still requires a weight distributing hitch. Past F150's have been limited to 5000lbs across the board if you use a regular weight carrying receiver hitch instead of a weight distributing setup.
  #67
Old 07-29-2014, 11:12 AM
paredneck33's Avatar
paredneck33
paredneck33 is offline
Tim lets not forget that the ecodiesel wasn't built to compete per say against the 2.7 and vice versa. However it was built to compete against the 3.5 ecoboost. And although it may get better unloaded fuel mileage I really don't think it gets any better when towing.
Not that I put much faith in the biased idiots at FTL Truck. But they did a video of the ecodiesel towing up the Ike Gauntlet. The truck did 3mpg. the grade and a little worse then the 3.5 ecoboost. Now some will comment on the fact that the ram was much closer to its max tow rating then the ford, but lets not forget that the ford also didn't have the maxtow package. And that when comparing these two engines side by side the 3.5 runs away from the ecodiesel with overall capability. And the 2.7 is much closer but slightly under the capabilities of the ecodiesel.
  #68
Old 07-29-2014, 11:13 AM
paredneck33
  #69
Old 07-29-2014, 11:28 AM
paredneck33
Engine Horsepower Torque (lb.-ft.) Payload (lbs.) Towing (lbs.)
2015 Ford F-150 4x4
2.7-liter EcoBoost 325 375 2,160 8,400
2014 Toyota Tacoma 4x4
2.7-liter four-cylinder 159 180 1,335 3,500
2014 Chevrolet Silverado 1500 4x4
5.3-liter V8 355 383 2,007 11,200
2014 Ram 1500 4x4 3.0-liter
V6 EcoDiesel 240 420 1,620 9,050
As listed on businesswire.com
  #70
Old 07-29-2014, 11:33 AM
paredneck33
2015 Chevy Silverado 1500 and GMC Sierra 1500 Are J2807 Compliant - PickupTrucks.com News
For the j2807 tow ratings on the GM 5.3. According to this their rating actually dropped.
  #71
Old 07-29-2014, 11:42 AM
smlford's Avatar
smlford
smlford is offline
As will virtually all the automakers when complying with the SAE regulations.
I for one, am happy to see this.
  #72
Old 07-29-2014, 11:50 AM
seventyseven250
While we're going off topic, I can't wait to see the full Towing specs for the entire lineup. Be interesting to see how the SAE J2807 figures differ at the very top end.
I see on Ford Fleet they have a preliminary 2015 guide out, with a note that the final version will be published in September 2014.
I'm not likely to buy the 2.7L engine, the 3.5 EcoBoost is just so good, and I can afford the fuel.
  #73
paredneck33
Not necessarily, Ford claims to have been using these same tests for several years. And from what I've read it seems as though the Rams are about the same if not the same ratings. I just find it funny that last year when GM debuted the new 5.3 they claimed that it would beat the ecboost on towing and mpg's. They also claimed that their 6.2 would beat Ford's 6.2 with the same and had best in class 12,000lb towing.
  #74
Old 07-31-2014, 05:16 PM
elemint's Avatar
elemint
elemint is offline
And still no mpg numbers..... This is ridiculous.
  #75
Old 07-31-2014, 09:37 PM
seventyseven250
Is it? I don't know, doesn't seem to be a big deal to me.
Quick Reply: What is the mpg of the 2.7???
