HPOP reseal?
Old 05-04-2014, 02:03 AM
Tyler.172's Avatar
Tyler.172
Tyler.172 is offline
HPOP reseal?
So im on a tight budget right now and as much as id love to buy a new better hpop im wondering if I could reseal it for less? what orings/oring kits would I need? along with any parts/pieces in there that should be changed ive never taken one off/apart before so its new to me
Old 05-06-2014, 09:58 AM
Tyler.172's Avatar
Tyler.172
Has anyone done this before? or is it better to just buy a new HPOP?
Old 05-06-2014, 10:33 AM
Hussler's Avatar
Hussler
Hussler is offline
Depends what your problem is. Is the pump leaking and why do you want to reseal? You can't disassemble the actual pump and replace internals.
Some kits from Riffraff Diesel .. High Pressure Oil Pump & Related
Old 05-07-2014, 01:53 AM
Tyler.172's Avatar
Tyler.172
Its just leaking is all, I assumed you couldn't replace internals, im just wondering can you do a complete reseal and if so what parts do I all need and would I be better off just buying new pump, I did look at riff raffs hpop stuff but I wasn't sure if that would be everything I needed or not. If its better to get a new one im looking at the T500, is that ok for a stock truck?
Old 05-07-2014, 04:43 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Perfect for stock or moded. T500 is a good upgrade and you will be ready in the future if you ever want to go bigger injectors and turbo.
Old 05-07-2014, 12:21 PM
Tyler.172's Avatar
Tyler.172
Sounds like that's the way ill be going then
econo93
01-24-2019 09:57 PM
cdude20
06-27-2013 08:07 PM
kirk2
13
07-03-2012 12:29 PM
jchosler
114
07-19-2010 01:18 PM
f350rebel
63
04-09-2008 07:14 PM
Quick Reply: HPOP reseal?
