quick question
Old May 5, 2014 | 05:53 PM
Salts's Avatar
Salts
quick question
when i do a diff service and transfer case fluid change i need to use Mercon right not Mercon V or is there something else i should use
truck is a 97 7.3 E4OD
Old May 5, 2014 | 06:09 PM
helifixer's Avatar
helifixer
synthetic atf in transfer. I have run several brands and classifications. normally mobil 1 of castrol merc V
synthetic gear lube in rear, gl5 if you have limited slip. I run 75w90 in mine.
Old May 5, 2014 | 06:30 PM
Salts's Avatar
Salts
can i run dino oil or do i have to run synthetic? trucks at 510k and i doubt its been serviced in the last 2-3 years
Old May 7, 2014 | 10:50 AM
helifixer's Avatar
helifixer
with that many miles I wouldn't worry about what is in it!
whomrig
1997 - 2003 F150
May 29, 2016 09:55 PM
stepside64
1997 - 2003 F150
Aug 31, 2005 06:17 PM
BSHORT
Oil & Lubrication
Feb 3, 2005 08:10 PM
aurgathor
Oil & Lubrication
Jan 16, 2005 12:50 PM
lwong
Aug 4, 2004 12:23 PM
