Truck stalls while driving
I was thinking it was the HPOP, but I was keeping an eye on the two hoses on the side of it. There was so much grime everywhere its been hard to see. I have pressure washed most of it off, but will probably take another round or two of cleaning before I can tell for sure where its coming from. But it doesn't appear to be coming from those hoses on the side, so I guess ill have to check out the plug under it. Could that leaking cause the stalls?
Sorry for my ignorance, I'm new to the diesels and the PO didn't seem to care enough to do anything bit routine maintenance.
After popping the hood I discovered the plug for the fuel bowl heater was disconnected and won't fully seat to lock in place. The truck starts and runs with it disconnected, but I'm wondering if that would cause it to stall eventually. I can't understand why it wont seat to click in place.
Well I got the answer on the CPS. It wasn't the problem. Made it a whole 2 miles this morning before truck died with no restart again. Of course because of a crash it took 20 minutes to make it the 2 miles. Anyway, think I'm gonna get the HPOP seal kit from international and the IPR seal kit as well. Hopefully that will take care of it. Any other ideas?
I haven't noticed that, but I really didn't get to start it again after it was warmed up, because it doesn't start after it dies until a while later. It started right up this evening after sitting all day where it died.
#29
So it was warm when it died, then wouldn't restart? That does seem to point toward o-rings. Either IPR o-rings or injector o-rings. I'd definitely start with IPR o-rings since it's the easiest and least expensive
I don't know of any way to test an IPR. It can get an accumulation of debris in it and become slow to react to pressure change commands from the PCM. They can be disassembled and cleaned if you're extremely careful to reassemble it exactly as it came apart. There are several videos on You Tube on doing it.
