no power to injectors
Old 04-21-2014, 06:02 PM
subford's Avatar
subford
subford is offline
Power from the Ignition switch closes the power relay and also powers the Ignition system.
Pin 37 & 57 are the pins that power the computer up and they get their power from the NO contacts of the Power relay.
The computer grounds pin #58 & #59 to fire the injectors.
Fuse "U" is powered by the Ignition switch:
Old 04-22-2014, 07:56 AM
brandonnichols's Avatar
brandonnichols
brandonnichols is offline
Originally Posted by mjc79
i tried my old 5.0 computer to test and see if it was the pcm and its the same way. the 5.0 computer was good before i swapped it out. i traced all the power and ground wires and nothing was broke or chaffed. all fuses and the diode are good. no burnt fusible links anywhere. its driving me nuts lol
I had as millibar problem where it would only start with brake cleaner and the. It would run perfect bit it was a bad PCM and the injectors would fire until it was started. I borrowed a friends PCM and it fried his computer where his truck had the same symptom. So it could possibly be a short somewhere in all those wires.
Old 04-22-2014, 07:57 AM
brandonnichols
similar * not millibar.
Old 04-26-2014, 05:22 PM
mjc79's Avatar
mjc79
mjc79 is offline
ok after alot of testing i figured out the ecm is toast. i think that 96 harness is what fried it. i put my 5.0 ecm back in it and can check codes and it will start up and run fine until it starts to lean out. guess its time to buy a new ecm lol. thanks for the help guys. this was so frustrating
BWD444
Electrical Systems/Wiring
23
07-09-2017 07:53 PM
Mkoch1991
07-31-2014 10:12 AM
beneckejames
04-17-2014 09:49 PM
Tazz54
05-27-2011 07:16 PM
89ford71
03-19-2011 11:37 PM
Quick Reply: no power to injectors
