6.0L LPOP problem
Old 04-15-2014, 11:59 AM
mudsmokinstroker's Avatar
mudsmokinstroker
mudsmokinstroker is offline
6.0L LPOP problem
Here's my problem guys hope someone can help I replace an injector then truck would not start cranked on it for 2 days so yesterday I took the oil filter out and held down the little valve and cranked the engine for ever and no a drop of oil came out. Then I pulled the regulator out and it was fine and wasn't stuck . So my ? Is cN the lpop be vapor locked and not allowing oil to come up.
Old 04-15-2014, 03:55 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
How many cranking sessions?
How long were you cranking the engine?
Pulling the oil rail allowed air to enter the HPO system and as a result it will take some cranking to build pressure and get the truck running again.
Old 04-15-2014, 05:22 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Do you show oil pressure on the instrument cluster while cranking? Make sure you keep the batteries charged and a break from cranking every 20-30 second so you don't fry the starter.
Old 04-15-2014, 05:43 PM
mudsmokinstroker
When i crank the engine i crank for about 30 sec then quit and the the bateries charge then i cranked again for 30 sec and still nothing the gauge in the dash only moves i tiny bit when i turn the key on and thats it. i put a gauge in the icp port and i built up to 20 psi thats it. so i pull the filter at and held down the pluger valve and cranked the in engine for like 50 secs and nothing came up dry.tried 3 times and nothing. Can i pour oil in the canister and try and crank it would that help the pump suck the oil? I dont get it truck ran great before injector replacement and now its like the devil is sitting in my engine.LOL I love my truck and just want it back.
Blakegregory
09-18-2014 04:23 PM
Whitetailhntr
05-11-2014 03:29 PM
BlackNM6.0
10-09-2012 10:15 AM
DROOPY209
1997-2006 Expedition & Navigator
12-31-2008 04:21 PM
muscle66
08-02-2007 06:56 PM
Quick Reply: 6.0L LPOP problem
