Speedometer issues
Old Apr 12, 2014 | 05:38 AM
Rodger49's Avatar
Rodger49
Speedometer issues
I have a 1991 F150 with a 4.9 motor, automatic transmission. Had to replace transmission and speedometer has never worked. I'm being told this model is all electronic and does not have a speedometer cable from the cluster to the transmission and I'm being told to replace the cluster panel. Can anyone tell me for sure whether a cable is required from cluster to transmission. I'm getting a lot of different answers, any help would be appreciated. Thanks, Rodger49
Old Apr 12, 2014 | 07:58 AM
Daniel5.0's Avatar
Daniel5.0
Electronic speedometer didn't start until '92.
Old Apr 12, 2014 | 07:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
as
Daniel said, your truck uses a speedometer cable out of the tail shaft of the transmission.
it is possible they put in a 92 and newer trans that does not have the tail shaft speedometer provision.
Old Apr 12, 2014 | 07:55 PM
RIKIL's Avatar
RIKIL
On my 92 I have a sensor (VSS) on the top of the rear diff. That feeds not only the PCM but the speedo as well. I wonder if you could check for that and if you don't have it, would that mean you don't have an electronic speedo? Of course, if you did have the sensor that could feed the PCM and not the speedo...just a thought.
Old Apr 13, 2014 | 08:52 AM
tjc transport
i ain't rite
91 and older was cable driven speedometer. 92 and newer is electronic speedometer run off the VSS in the rear axle.
Old Apr 13, 2014 | 08:55 AM
RIKIL's Avatar
RIKIL
Curious, with a cable driven speedo, how does the PCM know how fast the vehicle is going? Does it get information from the speedo?
Old Apr 13, 2014 | 08:57 AM
tjc transport
i ain't rite
no idea. i only had diesels with manual transmissions, so i did not have to deal with computers.
however ABS equipt trucks had a tone ring in the rear for the ABS. so maybe the computer gets its info from there.
Old Apr 13, 2014 | 11:49 AM
rla2005's Avatar
rla2005
Prior to 1992 the VSS sensor is inline with the cable drive assembly. On 4wd vehicles it attaches at the transfer case:
On 2wd vehicles it attaches on the transmission tailshaft. (Sorry, no pic)
Old Apr 13, 2014 | 11:51 AM
rla2005's Avatar
rla2005
On 1992 and later trucks, you are correct. The VSS signal is derived from the VSS/RABS sensor on the rear axle.
On 1991 and earlier trucks the PCM gets it's signal from a dedicated VSS sensor inline withe speedometer drive cable assembly.
Old Apr 13, 2014 | 01:22 PM
tjc transport
i ain't rite
none of my diesels had that sensor on the speedometer cable.
all i had was the plain cable on the transfer case. no tone ring on the rear diff either.
Old Apr 13, 2014 | 03:38 PM
eakermeld's Avatar
eakermeld
My 89 has a VSS on the rear diff and no speed sensor on the speedo cable coming out of the t-case.
Old Apr 13, 2014 | 05:10 PM
tjc transport
i ain't rite
mine might have something to do with the fact the 88 has a 86 10/25 rear in it, and all the others were F-350's
Old Apr 13, 2014 | 08:23 PM
rla2005's Avatar
rla2005
Perhaps I should have been a little more explicit. The VSS signal to the PCM is for controlling an electronic transmission, i.e. E4OD. If you have a mechanical automatic (AOD/C6) or a manual the signal is not required.
Old Apr 13, 2014 | 08:30 PM
eakermeld's Avatar
eakermeld
Does it serve any purpose on my 89?
Old Apr 13, 2014 | 08:47 PM
rla2005's Avatar
rla2005
The sensor on top of the rear differential is for the RABS system. When Ford started using the electronic speedometer in 1992 they used the RABS sensor for dual purposes. It's original function, rear anti-lock brakes, then used the PSOM to divide down the pulse count for use with the speedometer and PCM.
