HELP!!!!
Old Jan 30, 2014 | 10:18 PM
lemasters f100's Avatar
lemasters f100
HELP!!!!
I am changing my intake manifold and there is a stripped bolt. Any ideas on how to get it off?????
Old Jan 30, 2014 | 10:23 PM
HIO Silver's Avatar
HIO Silver
What engine n which bolt?
Old Jan 30, 2014 | 10:25 PM
lemasters f100
400 and left side closest to the starter. Closest to front
Old Jan 30, 2014 | 10:26 PM
lemasters f100
Intake manifold to engine block
Old Jan 30, 2014 | 10:36 PM
Scoop531's Avatar
Scoop531
Drill it is there any head left on it if so heat it up and try to remove or soak it for a few days with lube
Old Jan 30, 2014 | 10:58 PM
lemasters f100
It's almost completely round
Old Jan 30, 2014 | 11:09 PM
Scoop531's Avatar
Scoop531
Soak it every day for a few days go to Sears buy a bolt extractor for round bolts try that
Old Jan 31, 2014 | 04:17 AM
User 71024's Avatar
User 71024
if your replacing the intake you don't have to be careful with it, cut the head off with a sawzall, pull the intake over it and then it should come out easy.
Old Jan 31, 2014 | 06:56 AM
jasberale's Avatar
jasberale
+1 to all these suggestions. I'm not sure if you could fit the jaws in there, but I have had success using a plumber's pipe wrench. The one I have is about 8", and can get into most spots. If you put it on just right, the more you turn, the more it bites into the bolt. I have used it on probably a dozen stripped bolts and nuts over the years. Good luck.
Old Jan 31, 2014 | 07:18 AM
Dave145's Avatar
Dave145
Cut a slit in the head, and use a LARGE flathead screwdriver to get it out. Better still, get a LARGE flathead screwdriver bit and but it in an impact.
Old Jan 31, 2014 | 07:24 AM
tinaheels's Avatar
tinaheels
hammer on a smaller socket & remove it that way
Old Jan 31, 2014 | 01:07 PM
lemasters f100
Of tried hammering a socket on. Tried the pipe wrench. Not to sure about the screwdriver one due to it being torqued on. Gonna heat it up after school
Old Jan 31, 2014 | 02:23 PM
hivoltj's Avatar
hivoltj
what went wrong with hammering a socket on? I'd lean more towards freezing than heating the bolt. CRC the makers of brake-kleen make some cryo freeze stuff in a can, try spraying it with that. I find pounding on a 12-point metric socket just smaller than what it's supposed to take works best, best with an impact gun to rattle it loose also.
Old Jan 31, 2014 | 02:50 PM
HIO Silver's Avatar
HIO Silver
Weld a nut on it and back 'er out the normal way.
Old Jan 31, 2014 | 03:35 PM
OrangeBeast's Avatar
OrangeBeast
I have done that myself and as long as you get good penetration it works well, otherwise you just torque the nut back off. If I don't have a welder handy, I find a pair of vice grips will work well too. Lock that s#!t down on there as hard as you can.
