2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Predictive Maintenance?
Old 01-14-2014, 05:37 PM
Biscayne's Avatar
Biscayne
Biscayne is offline
I have a 2009 Expedition EL 4x4 XLT. Power seat and pedals but no navigation or automatic climate control. Below is a list of the things that have broke or needed repair since I have owned the truck. What I am browsing the forum for and picking y'alls brain is........ what is next? Currently 115,000 miles and no real problems at the moment.
Things done:
1. Traction control module replaced under warranty
2. bulkhead wiring connector seal on transmission replaced due to leaking
3. driver side door window regulator exploded internally
4. A/C blend door motor under dash broke (Twice!!!)
5. A/C fan speed switch partially melted behind the switch. Replaced switch and resistor card
6. Ford emblem on grill is completely delaminated and looks awful (not yet replaced)
7. New battery due to age and other maintenance stuff (plugs, trans flush, fuel system cleaned etc...)
Have you guys noticed any other frequently occurring failures on here? There may be more but I may have blocked them due to anger (it's hard to feel good about repair costs while you were still making payments).
Old 01-15-2014, 10:52 AM
berry1234's Avatar
berry1234
berry1234 is offline
I don't see anything outside of normal maintenance items that will come up. My starter went out at 134K miles, went through two fan clutches-under warranty. That's about it. If you focus energy on what will break, it will happen.
trk pny
01-01-2017 05:45 PM
4_Econolines
01-17-2016 08:47 PM
moose_j9
1997-2006 Expedition & Navigator
12-04-2010 09:44 PM
andruszh
09-18-2004 02:20 AM
Quick Reply: Predictive Maintenance?
