Ignition problem
Old Jan 12, 2014 | 08:36 PM
bra$$monkey's Avatar
bra$$monkey
Ignition problem
56 F100
351c
c4
I get no spark.
I replaced the coil
I have good voltage coming into the coil on the green wire (ign on) & not enough on the red wire to light my test light.
I have zero spark coming out of the cap.
I have a new wire running from the coil to the cap.
The truck has electronic ignition - I have no idea what brand or type.
Is there a definitive test for the pick up coil or some way to ID the ignition I have?
Now for the crazy idea - I have a 91 bronco with a 5.0 - would the dizzy & ignition pull out of that 5.0 & drop into the 351c? Just to test it? Crazy I know - but hey - its here & if that ignition will light my truck why not try.
Old Jan 12, 2014 | 09:35 PM
52 Merc's Avatar
52 Merc
302 dizzy won't fit in a Cleveland. Oil pump drive hole is smaller and the housing shorter.
Old Jan 12, 2014 | 11:20 PM
dmack91's Avatar
dmack91
I went with an HEI in my 289. It seemed easier than purchasing everything separately and there was a definite plus to only having to run a power wire and you are ready to go. The only issue I had was that with that tall of a cap I had to run a 1" spacer under my air filter assy. At less than $60 it is hard to beat if you are looking at replacing yours.
TSP HEI DISTRIBUTOR FORD 351C 429 460 CLEVELAND V8 50K V COIL BLACK CAP JM6506BK - Newegg.com
Here is a pic (I know it isn't a cleveland, but it gives you an idea of the size on a small block).
Old Jan 13, 2014 | 08:27 AM
bra$$monkey
That is incredible! I was getting ready for a 3 month journey trying to ID the components I have.
How can they sell an entire distributor for less than $60?
Coolness. I'll order 1 today.
Old Jan 15, 2014 | 10:09 PM
dmack91's Avatar
dmack91
I won't tell you that I got the one for my 289 for $38 shipped through them then. I was trying to make a list of what I would need, but when I found this I was sold.
If you are already running an electronic Ford dizzy, the plug wires should even fit the new HEI.
Old Jan 16, 2014 | 06:01 AM
bra$$monkey
I ordered mine from amazon. Should be here soon. I hope to drop it in this weekend.
Old Jan 18, 2014 | 05:08 PM
bra$$monkey
Hey guys - Update.
I dropped the new dizzy in this morning! It took a couple stabs, but it was good family time with my 12yr old son too.
I had a heck of a time getting the oil pump shaft to line up. I eventually had to take the old distributor, pop the cam gear off & use this as a tool to turn the oil pump shaft in order to get it to line up for the new shaft.
So - the truck POPs right to life!
I have a couple things I need to finish up.
1) haven't hooked up the Tach yet
2) Need new plugs & wires - I broke a wire while playing around & when I pulled a plug to get on the compression stroke I noticed the plugs were pretty nasty.
3) The dist is tall (I knew this) & the air filter no longer fits. The radiator hose touches it too. I will be finding an extender or something to raise the air cleaner & I may swap out to a new radiator hose.
4) I still have to remove the old coil mounted on the firewall & clean up the wiring a little.
Thank you to all for helping me with this - it truly was a cheap fix & this new dist. is much nicer than my old one.
Go Team!
Old Jan 20, 2014 | 01:14 PM
dmack91's Avatar
dmack91
I ran into the height issue too, and was able to add a 1" spacer to get the air filter to clear. It just seemed like a simple and inexpensive fix to troubleshooting a cobbled-together system like I had on mine from the PO.
Glad to see it worked for you.
Bruce in SC
Apr 26, 2026 06:53 PM
MitchellD
19
Aug 5, 2017 08:14 PM
Montana Workhorse
21
Dec 31, 2016 04:27 AM
Tonto Kowalski
Sep 7, 2013 04:56 PM
Norm Spaulding
15
Mar 10, 2008 07:23 PM
