2003 Explorer Rear end "popping, clicking"
The 1/4 inch of play, is that rotational movement or in and out movement? If rotational, then that doesn't sound like an issue. If that's in and out, then it sounds like you either have wheel bearing issues or an axle shaft nut that is loose.
Since the noise only is present under braking and coasting, I'd suggest a careful inspection of the brakes followed by the suspension components, and if there's still nothing obvious, drain the rear differential fluid and look for signs of metal.
-Rod
-Rod
RSCHAP1
28
09-18-2018 07:00 AM
devozoo
04-12-2012 05:30 PM
golfdrinker
08-03-2009 08:57 PM
rubersole
09-03-2006 03:39 PM
the lead truck
02-11-2006 06:26 PM
