Seat belt get stuck
Old 12-17-2013, 10:10 PM
michellehmcclure's Avatar
michellehmcclure
michellehmcclure is offline
Seat belt get stuck
My Sons 1977 F250 truck has 3 point retractable seat belt. The bottom retractable part keeps getting stuck. Any idea how to fix it easily.
Old 12-17-2013, 10:16 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Originally Posted by michellehmcclure
My son's 1977 F250 truck has 3 point retractable seat belt. The bottom retractable part keeps getting stuck. Any idea how to fix it easily.
Stuck out or stuck in?
Typically, the belt gets twisted and then inhaled and trapped by the housing. To avoid future issues, unbuckle and guide the belt into the retractor while ensuring the belt is not twisted.
If it is stuck out, ya need to pull it on it firmly so the internal cam releases the toothed gear. It can also stick if yer parked on a hill.
Good luck there mom.
Old 12-17-2013, 10:20 PM
michellehmcclure
It just won't come out when you pull on it. Its not twisted. It like locks on the bottom strap.
Old 12-17-2013, 10:23 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Try guiding it in slowly, all the way to the bottom, then back out slowly. If that doesn't work, the seat belt may need to be replaced. They're not meant to be taken apart. You can typically find replacement seat belts on eBay or in the junk yard (if you're okay with that); some places also redo them through the mail.
Old 12-18-2013, 01:36 AM
rockittsled's Avatar
rockittsled
rockittsled is offline
just as a "drive it until I can fix it" I cut the plastic around the base so I can stick a fingernail under the little latch that goes across the belt and then lift it and gently pull on the belt. it still latches and holds the belt..... Redneck as heck, but oh well
Old 12-18-2013, 10:15 AM
michellehmcclure
Awesome Ill try that!!
mwsF250
1999 to 2016 Super Duty
10-04-2011 02:54 PM
bigcountry1009
16
12-14-2008 07:05 AM
Green Ford
06-22-2008 04:52 PM
whayes75
03-24-2008 10:10 PM
Quick Reply: Seat belt get stuck
