5.4 Cold weather transmission sticking
Old 12-10-2013, 09:16 AM
coleaukee's Avatar
coleaukee
coleaukee is offline
When I fire up my rig when its below ten degrees, even in neutral or with the clutch depressed, I can feel the motor trying to engage something in both the stick and the clutch pedal. It is enough to make the motor sputter and die. If I hammer on it for a few seconds i can feel it breaking up then it runs great. Any suggestions on an alternate gear oil that I wont lose protection with. Any ideas will be great!
Thanks!
Old 12-19-2013, 10:12 PM
wbrook_ford's Avatar
wbrook_ford
wbrook_ford is offline
How about one of those stick-on oil heaters? If it's that cold you should also have the block heater plugged in.
If the clutch isn't releasing, sounds like pressure plate or throw out bearing issues...
BigBlockF350
1999 to 2016 Super Duty
09-30-2013 11:07 AM
madpogue
01-01-2013 09:12 AM
bocephus_3349
12-12-2009 05:18 PM
gfl
08-20-2009 10:55 PM
SoArkSI
11-05-2005 09:10 PM
Quick Reply: 5.4 Cold weather transmission sticking
