97 PSD Build Up!!! On A TIGHT Budget!
#226
Update: Slowly but surely doing some stuff to her so here we go:
Just installed an AFE pro dry s stage 2 cold air intake, got it brand new for$100 from a buddy, was sitting in his garage for a couple months because he sold his obs, you cant beat that deal!
A few minutes ago i just finished up installing some KC Highliter off road lights, they are 130 watt, 200,000 candle watt power!!! Mounted them behind the grill, they are EXTREMLY bright!!
A little before after
Also i will be installing tomorrow, i basically stole it from walmart, Pioneer head unit and 4 50watt speaker combo package for $85!!!!! Basically bought the head unit and got the speakers free, that will really make the ol girl sound like a mercedes inside!!
The next items planned are:
4in straight pipe
tuner
removal of visor
front leaf spring conversion
4in straight pipe
tuner
removal of visor
#227
I'm on my phone and for some reason cannot view the pictures throughout this thread, but isn't your truck 2wd??
If so, DONT try to put leafs on it... I'm not going to go into my rant about how ridiculous it sounds that anyone would want to do leafs on a twin I beam front end or even swap to the F-SD solid front.... JUST DONT....
#228
#229
#230
So he took the coil springs out of a 2WD truck and put leaves back in and left it a 2WD? Or are you saying he put a 4x4 front axle under it and converted to 4x4? I can't think of ANY reason why you would want to convert from coil springs to leaves unless you're going 4x4. There are guys spending major time and money to be able to convert the 4x4's TO coil springs (05+ 4x4 conversion) because they make it ride so much nicer.
#231
If your buddy put leaf springs in his 2wd front end, he has issues..... if he swapped to 4x4, theres more to that than just swapping in some leaf springs....
#232
#233
OK.. 4wd swap, not just a leaf spring swap. Got it. Lol. It'll be fun getting front shackles on your 2wd frame. Doable, just not near as easy as the TTB trucks. Easier at this point to do the 05+ stuff with coil springs, but thats quite a bit more expensive. Lol
#234
#235
#236
Well i think i am going to keep it 2wd, i did some major looking, determined to find some type of lift for my truck and found this gem?? Made for the 2wd!! WHat do you guys think, its pricey but its the only one for 2wds 92-97 F250-350 2wd Level Kit
#237
I don't see the point in lifting a 2WD truck. All it will do is throw off your alignment, put additional strain on other components and reduce your fuel economy while you gain absolutely zero in terms of functionality. That's probably why you're struggling to find a lift kit for a 2wd truck. That kit is designed to do no more than level the truck out to eliminate some of the "rake" that comes standard thus the title "leveling kit. When you do that and then load up the bed with something heavy or hitch up to a trailer with a decent tongue weight, then the front of the truck sits higher than the rear and it looks goofy IMO.
I personally think it looks great just the way it is but it's your truck so do what you like with it.
#238
