my winter list
#182
#183
well,today was such a beautiful day today. I got a little bit to work on ol clifford. I had the main fuel filter bracket cut out from before. I mocked it up and tried it on the truck and built a couple fuel lines. IF my fittings had come like they should have friday. I would have had it all welded on and plumbed. I am going to wait because there is a compression that will need installed before I weld the bracket to the frame.
#184
#186
#188
#189
Don't worry. I had hoped to pull the OBS in the shop for an oil change, fuel filter change, new oil pressure switch, air filter, and mix up some water methanol so I could go for a last hoorah at the track tonight. I ended up in Houston helping a friend load a skid steer he bought and wound up playing on that a few hours when we got home. The only thing I did to the OBS was change the oil pressure switch. No track time for me tonight. Doing an injector job with Cody instead. Lol
#190
#191
I'm going to order the parts for mine that we'll need on mine wen we get started on the bad injector rings glow plugs and all the other bs that is going wrong on it. I'm frustrated too man. I hope to get to help you this weekend and some this week. I hadn't heard from u in a while so I thought I'd check in on ya! I fixed dad's Lincoln idler and tensioner this am. Text me.
#194
I really appreciate all you do to help. I really want to return the favor so please call me when you work on the truck and bronco! Where should I buy the o rings for the injectors?
#195
