87 F250 4.9 Injection problem
Yes one has a light blue stripe!
Yes I had towed it to a shop and they told me i had 30psi at the rail relief.
Yes The engine fires up and runs great untill the shot has ran out.
(I always joke about strapping a gas can to the top because thats the only way it runs)
Other info:
My injectors noid dimly last time we checked at the shop.
I'm fairly positive the Relays are correct
I know my injectors aren't squirting fuel
Other info:
At the shop now or?
I just read your old thread, yea I'd agree you have a electrical problem and by sounds of it, as it effects both injector banks and equally based your statements. Two separate circuits, odds both damaged equally be slim so likely problem is before that, sounds like grounding issue to ECC (subford covered that). Its getting there (or just getting a false read) but its so weak its not enough to pull injectors open spray fuel.
Those circuits need testing, locate where the problem is.
At the shop now or?
(To hard?)
I doubt the new eec is bad, might be but doubt it. Seems to me they'd test them before sending them out.
Verify the truck cab is grounded to the engine block.
Verify pins 40 and 60 at EEC harness connector are getting solid contact to bat ground.
Verify pin 20 at EEC harness connector has solid connection to engine block.
EEC pinout diagram,
Fuel Injection Technical Library » EEC Computers (scroll down you'll see it)
Connector with 60 pins, "EEC-IV".
Make sure the harness connector is free of corrosion, no green stuff down in the little holes! If in doubt get a can of electrical contact cleaner and flush it out, check em all.
Make use you apply a thin coat of dielectric grease after cleaning connector, little bit goes a long way don't over do it. light smear over every hole is enough, just enough so each pin gets a light coat on the way into the connector.
That's after you've checked out every circuit.
Test every circuit for continuity.
For example test injector circuit, test injector bank #1 first. Set your multi meter for "continuity" touch one probe to pin 58 in the EEC connector, touch the other probe to each of the injector connectors Tan-org wire injectors 1,3 and 5. You should get a strong reading, very near touching the probes directly to one another. Also test the circuit for continuity to ground.
Then once satified everything with that circuit tests ok move on to the next.
Next test injector bank #2, do the same thing as above but now between pin 59 EEC connector to injector connectors Tan-red 2,4 and 6. And again verfiy does not have continuity to ground not even a little bit.
Then check pins 20 40 and 60 as mentioned above, verfiy they have good continuity to their appropriate ground.
This testing shows the wires are good, no continuity = no juice flow the wire is damaged/burnt/cut/broke/pinched whathaveya.
If circuits test out ok, you know the harness connector is free of corrosion all pins are clean they make solid connection with the EEC when its in place, and still no start? then you know to look elsewhere but you must do that first. Myself based on what you've stated in your old thread and this one I think that testing will show you where the problem is.
No not at the shop I'm working on it at home because they didn't want to deal with it.
(To hard?)
Yea its a time thing, its gonna take time to narrow it down and "time" you probably don't want to foot the bill for either!, better off doing it yourself.
Post back when you've had time to check it out and or have more questions somethings not clear.
EEC pinout diagram,
(To hard?)
Regardless you should have a ground strap run from the firewall of the truck to the engine block, if you don't? install one.
This is what i got so far still no luck!
I have to hot wires all the time two yellow
one wire that kicks on when key is turned (white/blue)
other wires
solid black (not sure what it goes to)
red (Test to pin #59 so i think its the second bank injectors)
red (Another red wire i believe it is supposed to kick on at ignition but it don't)
tan (goes to test #6) (Fuel pump i believe)
brown (not sure what it goes to any help would be nice)
can take pictures and post as a link to Facebook but i'm not sure how to post them any other way, i'm not to computer savvy.
other wires
other wires
other wires
Red wire is power to few things on the engine including power to all of the injectors, injector banks do not have separate power supplies. If you only have power to half of them find out where the problem is in that circuit.
Do you have a wire diagram to work from or do you need one?
Any pictures posted to facebook might not be visible to others here, take me for example, no FB account.
Better option get a free account from hosting site such as Photobucket (there are others too), upload your pictures there and then link to them here.
Might be the fuse link feeding red wire out of the EEC relay yea but might be the failure is before gets there..... unless you already tested both those points of course?
Are you sure the EEC relay is good? and that it has key "on" power to it via Wht-lt blu wire?
I just bought the EEC relay last year.
Perhaps it could be bad but i just had it tripping the other day?
The red wire use to have power but now it wont kick on i think i blew a fuse link of some sort.
The red wire does trip a sensor on top of the throttle body though which it didn't before.
#28
Unless they didn't test it.....just blew smoke up your ***, "30psi" tested at the fuel rail tells us the EEC relay is good and getting power out beyond that point that blue fuse link is "good".
#29
#30
You'll see couple large posts on it, the Positive cable from the battery will connect to one of them, the fuse links will all be on that same post.
Check them all but the one most concern with if no longer hear pump run will be "Brown".
Don't assume you have one bad connection either, its possible you have several all combine causing you grief, might be one but likely to be more than that depending on where you live, that comes into play too.
