WIRING HARNESS: '02, 7.3, 42-PIN BACK TO VC's
Here's a picture of the one I have. It's got all the same stuff my e99 has except it also has this aluminum contraption with two connectors to it (I don't recall seeing this under my hood). You can see the feed wire that I cut and I have the rest of that so it can be spliced back together. I was not able to get the 42 pin connector apart tucked back under the hood so I cut it off but I cut it on the right side of the connector to save the harness. The connector did suffer a chip but it should still work. If you want it PM me. I'll let you have it for a lot less than $300-$500. I am not finding a part number on the harness.
Mark
Mark
As for you guys working out a deal for your harness, unless you're gonna give it to him for the cost of shipping, please take it to PM's. Selling in the tech forums isn't allowed.
Thanks.
Stewart
Main engine harness
I know its been a while since this repair has been done. but do you still happen to have the contact info for the guy that got you the harness. i have a 2000 superduty and a rat chewed through the harness and no one can find me one and my parts guy from ford said that they dont show anyone in the country to have a harness
Also try the local Navistar or International Harvester dealership for their PN 1837761C91. Ya never know.
There are a few of them on FleaBay from sellers with good reputations.
http://www.ebay.com/itm/99-03-Ford-F-250-350-450-550-Super-Duty-7-3-Diesel-Engine-Wiring-Harness-OEM/201684037333?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D40147%26meid%3D14b0d73fdd604535b995edba2c9e69d6%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D282209000886
Looks like Tasca Ford has the 49 state, non-GPCM PN F81Z12B637FA mentioned above in stock for $565. Engine Wiring Harness
I'm having the same issue with the insulation falling apart on the main wiring section.
Thanks!
