The PA Chapter's "Punkin' Chunkin'" October 2013 Chat and B/S Thread
#422
Might be. Do a pressure test. Is it using coolant?
Could be an injector. Try getting a can of the injector cleaner that hooks into the fuel rail, and see if that helps
#423
Random: if I were to get duals for the Expy - would they be bent similar to duals for an F150? Trying to figure how to explain to the pipe shop...
#425
Mine split at the muffler, then come straight back, then right pipe is almost like stock.
Left pipe takes a hard turn after the rear, then another hard turn at the frame.
Both pipes are outside the hitch
#429
I'll look into trying that Charlie. Thanks. I'll have to ask about the anti-freeze.
Here's a something to look at. You can have the tails bent to exit behind the tires.
http://www.ebay.com/itm/Ford-F150-07-13-Dual-Exhaust-Kit-Flowsound-1-Chamber-/141075203456?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d8bcc580&vxp=mtr
#430
That's similar to what I have Scott.
Got a set on the 94, the 95, and had a set on the 86. They are holding up fine. Going straight out the back is ok on a pickup, but he may want them bent to the sides incase he runs with his rear window down
