gearing recommendations
Old 09-21-2013, 01:26 PM
amd_038's Avatar
amd_038
amd_038 is offline
hey guys
just wondering if anyone can help me out with gearing recommendations for my truck the gears are stock right now.
i have a 06 f 350 with a carli lift and 38 inch tires
head studs, egr delete, idp street tunes and mtw hybrid turbo
i dont tow often but do probably equal city and highway driving.
also im up and down logging roads fairly often.
i would definitely like to see it quicker off the line.
thanks
Old 09-21-2013, 04:58 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
So currently you're running the factory 3:73 (axle code 3L on the door sticker)?
Here's a handy chart with all the Ford axle codes:
Ford F-250/350 Series Gear Ratios
Old 09-22-2013, 10:53 AM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
4:10-4:11 would allow you to go to 40" if you want probally, better mpg in city. should bring you rpm's up to what you stock rpm's were with stock tires. A true 4x4 shop or speed shop could help you out better.
Old 09-22-2013, 02:00 PM
amd_038's Avatar
amd_038
amd_038 is offline
yes im currently running 3:73
Old 09-23-2013, 11:33 AM
Firemudder's Avatar
Firemudder
Firemudder is offline
Use the new gear formula. New tire diameter ÷ old tire diameter x current gear ratio = new ratio.
Old 09-23-2013, 12:07 PM
JBSIXGUNS's Avatar
JBSIXGUNS
JBSIXGUNS is offline
What rpm are you turning at 65mph? I run stock size 235-85-16 (31 inches tall) with factory 4:10 gears, and my truck is a beast off the line. At 65mph its turning 2000rpm on the nose. With you running 38"s I would think you would need to go lower than 4:10... Maybe 4:56 would be closer to what you need.
akaFrankCastle
02-27-2016 08:07 PM
MusicBro
09-19-2015 09:32 PM
homr75
1999 to 2016 Super Duty
08-19-2012 02:11 PM
spraydawg
17
02-12-2012 02:56 PM
moose94
08-27-2003 11:27 AM
Quick Reply: gearing recommendations
