Newbie 85 f250 frame off resto (Image Heavy)
Old 03-04-2014, 07:30 PM
Piston Honda's Avatar
Piston Honda
Piston Honda is offline
Got a few things done today. I brought the balancer down to the local machine shop and got it sleeved, forgot to take a pic but it's done, 12$. The new non-EGR intake is installed along with the carb and fuel hoses. I just mocked up the hose from the pump to carb but will eventually use SS braided hose I think.
I'm going to order locking header bolts as well as locking collector bolts tonight.
The headers come with gaskets, but was thinking about getting some better quality ones. Has anyone used Remflex gaskets before?
  #212
Old 03-04-2014, 07:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Did you ever get the pulley off your alternator?
  #213
Old 03-04-2014, 07:35 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
That engine looks great, what kind of paint is on the valve covers? or is it powder coated clear?
  #214
Old 03-04-2014, 07:41 PM
Piston Honda
No, I need some kind of carbide bit or something to remove some of the mushroom.
  #215
Old 03-04-2014, 07:48 PM
Piston Honda
Thanks, you can't see it from this pic, but there's a big run in one of the covers. I painted them when it was still summer and it was getting dark out, so that's my excuse. I used Duplicolor cast aluminum and then Duplicolor clear engine enamel.
  #216
Old 03-04-2014, 07:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Carbide burrs are expensive and brittle.
Maybe a chainsaw sharpening grindstone would fit right down in there?
  #217
Old 03-04-2014, 07:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It really does look great!
Where did you get your stainless bolt kit ?
  #218
Old 03-04-2014, 07:56 PM
FordFETruck
Looks like an ARP dress kit.
Here's my engine.
My engine is sporting Duplicolor engine enamel too!
Except I did a crappy prep job on the front of the heads, I'll fix that this summer.
  #219
Piston Honda
Is there a chainsaw sharpening grindstone that goes in a drill or a die grinder?
  #220
Old 03-04-2014, 08:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have ones that fit my Roto-Zip and Dremel tools.
Do you have an 1/8" collet for your die grinder?
They usually have reducers in the Roto-Zip displays.
  #221
Old 03-04-2014, 08:11 PM
Piston Honda
Here's my engine.
Looks good, how did you set up your alternator without using the smog pump bracket? It looks like you don't have any bracket there.
Yeah, it's an ARP bolt kit. I had issues with the kit, there were multiple bolts missing or the wrong length. At first the gentleman on the phone at ARP didn't seem to friendly, but they did end up sending the correct and missing bolts.
  #222
Old 03-04-2014, 08:13 PM
Piston Honda
I'll have to check out the reducers tomorrow.
  #223
Old 03-04-2014, 08:17 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Chain saw grindstones are about $3 vs $30 for a brittle carbide burr.
  #224
Old 03-04-2014, 08:19 PM
Piston Honda
Here's my engine.
Also, I see that you used the stock oil cap that runs back to the air cleaner. If you notice I am using a different type of oil cap. What's the difference between the two caps? Is there a benefit to the hose running to the cleaner?
  #225
Old 03-04-2014, 08:29 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You're sucking clean filtered air into your engine???
As for an alternator bracket, you can find them at JBG or cheap on Ebay.
Quick Reply: Newbie 85 f250 frame off resto (Image Heavy)
