Newbie 85 f250 frame off resto (Image Heavy)
Old 02-20-2014, 10:43 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
See if you can send it back, it's not worth trying to mess it up to plug those holes. If you don't plug them, lots of exhaust will be coming out of those holes.
  #137
Old 02-20-2014, 10:45 PM
Piston Honda's Avatar
Piston Honda
Piston Honda is offline
It's already been installed though, do you think they will take it back?
  #138
Old 02-20-2014, 10:46 PM
FordFETruck
Don't tell them it's been installed, just say it's new and never used. Technically it hasn't been used yet.
  #139
Old 02-20-2014, 10:52 PM
Piston Honda
I give it a try.
Another question. If I have a sending unit in my tank do I need the mech pump?It had both to begin with.
  #140
Old 02-20-2014, 10:55 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Edelbrock said that manifold is a direct replacement for the 4V HO manifold. That being the case the exhaust gas comes up through that hole and into the EGR valve itself. Lots of guys on here have made block off plates with everything from a Coke can to stainless steel sheet. You will need a gasket on the manifold, your block off plate, another gasket, and then the carb. And the bottom gasket has to fully cover the hole, as does the plate.
  #141
Old 02-20-2014, 10:57 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
The sending unit, meaning just the float and resistor combo, is used with a mechanical pump on the engine. The in-tank electric pump usually includes the sending unit and you don't need the mechanical pump on the engine.
  #142
Old 02-20-2014, 11:01 PM
Piston Honda
Seems like a lot of potential for leaks. Intake, gasket, plate, gasket, spacer, gasket, and carb.
  #143
Old 02-20-2014, 11:03 PM
Piston Honda
I tried sliding the mech pump in the timing cover today and it doesn't seem to want to go in. Any tricks?
  #144
Old 02-20-2014, 11:14 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
There are potential for leaks, but it can and does work. You might find a commercial block off plate that is less likely to leak.
The arm on the pump is hitting the actuator cam and you are compressing the spring in the pump as you tighten the bolts down. Turn the engine half a turn or so and see if it gets easier. There are points in the engine's revolution where the arm is just barely compressed and places where it is highly compressed - which is where you probably are.
  #145
Old 02-20-2014, 11:16 PM
martin72's Avatar
martin72
martin72 is offline
Trucks coming right along looks good.
  #146
Old 02-20-2014, 11:25 PM
Piston Honda
Your the best! I'd be lost without everyone on FTE........let's face it I'm lost anyway
Thanks! I'm at a point where everything seems to be giving me trouble right now
  #147
Old 02-21-2014, 08:07 AM
Piston Honda
Ok, so I peeled the intake of the motor and it's not that bad. The RTV should clean up no problem.
I believe the one I need is #2181. Before I order the new one, should I know anything else?
  #148
Old 02-21-2014, 08:10 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I agree you want the non-EGR unit, and if that is 2181 then go for it. I can't think of anything else.
  #149
Old 02-21-2014, 12:49 PM
Piston Honda
I found a spacer to use with the installation tool and I'm trying to get the harmonic balancer on I think it's all the way on but the pulleys don't seem to line up correctly.
I measured the depth of the stub on the back of the balancer and I don't think it can go in any more. Why don't the pulleys line up? Am I missing something?
  #150
Old 02-21-2014, 03:50 PM
Cole Neese's Avatar
Cole Neese
Cole Neese is offline
In the top picture, is the inside of the balancer flush with the crank snout? I can't tell from the pic. If it's not I'm pretty sure it needs to go farther.
Quick Reply: Newbie 85 f250 frame off resto (Image Heavy)
