Transmission swap thoughts C4 to AOD or 4R70W
Hey guys,
So I think I should have a good bit a refund money to do my project but I have been on the fence with that to get. my 73 dent has a c4 transmission which as you know is terrible for high way cruising. So I am looking to swap with an AOD or a 4r70W. I have been on the fence with the two because one will be easier now the other will be easier overall. What do you guys think? Also do any of you know how to rebuild or knows some who rebuilds them?
I will eventually have dual exhaust and a 306 crate engine so I want to plan ahead accordingly.
I have been on the 73-79 dent forums and they gave me their opinions, but I want to ask you guys since maybe whats available or possible in GA would sway my judgment.
Thanks again guys for all your suggestions.
Classic to modern retrofit.
Ok guys,
There is some good stuff out there if you are interested in doing this swap in a classic ford or any truck that didn't have a OD gear.
Instead of re creating the wheel, I will link some of the research I have done. I just bought a rebuilt transmission from a 99 explorer off of Craigslist. These transmission are the best solution and have the widest gear ratio stock. The only kicker is you are going to need a stand alone controller unless you can wire something up yourself and you will need to shorten your driveshaft. I was originally going to go a mechanical AOD but When I learned that I might want to change gear ratios for better daily cruising I decided on the 4R70W. The seller sent me some diagrams that I will include here. after the links
Classic Broncos .com - Tech: 4R70W Transmission Swap into an 66-77 Early Ford Bronco
AODE-4R70W Electronic Automatic Conversion
BEC AODE & 4R70W Information
on
The wife and I had a discussion on what direction we wanted to go with the 79 this weekend. We decided to pretty much try and keep it just the way it is. It belonged to her father before he passed away so we want to just get it road worthy and reliable again but try to keep it pretty much the way it was when he drove it.
I am going to change the paint color, because faded out grey is just not for us and I had talked to him about painting it a different color before he passed away.
Think and easier electric OD swap would have been E4OD. It is self contained only needing the transmission computer, switch, and TPS. would have been an easier swap. The diagrams he sent you are the ones straight out of the Ford manual. I thought you were going miechanical OD
seancaros
54
06-29-2019 05:42 PM
Ponchopete
03-23-2015 06:36 PM
DASZU
05-13-2011 08:12 AM
