Crate Engine
Old Sep 5, 2013 | 05:11 PM
Oxfordrider's Avatar
Oxfordrider
Crate Engine
I am thinking about purchasing a 351W crate. It is still wrapped in plastic and has been sitting for 4 years (abandoned project). Should I be concerned about it sitting for so long. What should I be looking for before I buy it?
Thanks.
Old Sep 5, 2013 | 06:24 PM
nflfreak43's Avatar
nflfreak43
Was it kept oiled, was the rocker arms already tightened down, receipt to show what all is a part of the engine rebuild, people sometimes forget what exactly they bought after 4 years of it sitting
Old Sep 6, 2013 | 02:47 AM
baddad457's Avatar
baddad457
Moisture damage and/or rust.
Old Sep 6, 2013 | 10:43 AM
daveengelson's Avatar
daveengelson
If long block, I would check if seller would let me fill with fresh oil, use an oil pump primer tool to check flow thru oil passages; especially thru the rocker arm assembly, then check if crank turns. If all checks out I would make an offer considerably less than cost to seller. Not an authority but would assume if there were going to be any issues as a result of setting it would be at the top end which could be rebuilt relatively cheap???
Old Sep 21, 2015 | 06:42 PM
ALAN_50501's Avatar
ALAN_50501
I just brought a new 5.4 crate for 5,192 everything is new even comes with oil and filter
JimNolan
Sep 23, 2005 05:33 AM
bloodwood70
Bronco II
Dec 11, 2003 08:16 PM
RNMCGUIRE
Dec 10, 2002 08:16 PM
darkman
Aug 16, 2002 03:54 PM
