Looking for high-end water pump
I'm not sure if the aluminum pumps are still available.
Try FORD Y
It will be a pump with car dimensions which will require a matching car pulley.
If it will be used primarily for drag racing or local car shows, you can try Ted Eaton for an electric version.
Eaton Balancing | www.eatonbalancing.com
A stock pump should cool a stock or even modified Y well enough. Do you have a cooling problem or simply want some bling?
Try FORD Y
jvmcc
07-18-2016 05:40 PM
Tilleyman
11-20-2014 07:19 AM
Stephen67
06-12-2014 02:54 PM
1954F250
03-09-2006 12:38 PM
