Oxygen sensor?
Old Jun 15, 2003 | 01:24 AM
carpe_diem's Avatar
carpe_diem
Oxygen sensor?
1989 F250 hd 460cid
Where is my oxygen sensor located? I cannot find it.
Old Jun 19, 2003 | 10:19 AM
steve83's Avatar
steve83
Oxygen sensor?
Somewhere on the Y-pipe, usually JUST upstream of where the 2 sides join.
Old Jun 21, 2003 | 09:28 PM
carpe_diem's Avatar
carpe_diem
Oxygen sensor?
I have 90K on this O2 sensor, will probably replace it at 100K. They do deteriorate periodically even if no codes are shown. A new O2 means not just better mileage, but also better performance.
Old Jun 22, 2003 | 12:39 AM
LxMan1's Avatar
LxMan1
Oxygen sensor?
Yes, they get carbon built up on them after awhile. I believe that they recommend changing them every 60,000 miles. Make sure to put a good high-temp anti-sieze on the new one or it will be &#%@ to get off the next time if you don't.
Jimmy
Old Jun 22, 2003 | 09:00 PM
carpe_diem's Avatar
carpe_diem
Oxygen sensor?
I believe you about the anti-seize compound! I already went through that on the 5.7L small block. Had 160K on the O2 sensor and almost gave up trying to remove it. But got a 1/2" drive breaker bar and spayed the sensor with PB blaster overnight and finally removed it. Made a difference in performance.
How do you access this one, anyway? From under the truck?
Aungelique
Aug 28, 2019 01:49 PM
wikdwest
Jul 19, 2014 12:12 AM
chip.carden
Aug 10, 2011 07:57 AM
douglas3394
Aug 1, 2009 08:46 PM
explorer724
Oct 12, 2003 02:01 PM
