differences
Old Jun 11, 2003 | 04:15 PM
tony3068's Avatar
tony3068
differences
what is the diffence in engine size and the body style of the truck between the f-150 f-250 and f-350. thanks for any help
Old Jun 11, 2003 | 04:22 PM
jbalestri's Avatar
jbalestri
differences
Do you have a specific year you are thinking about? That'll help a lot.
Old Jun 13, 2003 | 08:51 AM
tony3068's Avatar
tony3068
differences
i was thinking just in general, but the newer years would work
Old Jun 14, 2003 | 10:10 PM
bigreave's Avatar
bigreave
differences
For the 80-86 I have owned F100 150 250 all the body parts are interchangeable. the only problem I every had was pulling the 400 from my 82 f250 super cab longbed and putting it in an 1980 150 it did bolt but i think the frame on the 250 was a ilttle wider but the engine did bolt up in th esecond set of bolt holes in the cross memeber. I think ford put almost the same engines in all there trucks becuase i have seen 300 sixs in 3/4 ton truck several times.
Old Jun 15, 2003 | 01:03 AM
81blueford's Avatar
81blueford
differences
Well...i'm glad i accidentally clicked on this thread...b/c i just bought a 82 f-250 and was wondering if parts from my 81 f-100 would be compatiable!
ttyl
ttoliver@scrtc.com
Old Jun 15, 2003 | 09:02 AM
bremen242's Avatar
bremen242
differences
I swapped in an 85 f-250 351W motor & motor mounts into a 90 f-250 diesel frame. so far so good.
as far as i could figure, mine 84 2wd,85 4x4, and 90 frame all look like the have the same dimensions, except the 90 doesn't have a hole for the oil filter for the windsor series, and is missing a bolt hole for the left inline six mount.
a question is (for me at least), does the 460 mount on the top of the crossmember like the 90's diesels, or does it mount behind the crossmember with mounts similar to the the Windsor series?
Old Jun 18, 2003 | 04:43 PM
jbalestri's Avatar
jbalestri
differences
Scroll down on this members site.
http://fordcowboy2000.clubfte.com/Cowboy'sF-150.html
He has the history of the Ford truck on there.
Old Jun 20, 2003 | 12:59 AM
Txquadhunter24's Avatar
Txquadhunter24
differences
i've got a 82 f100 flareside full body and all setting on a 95 shortbed frame, everything from those 2 trucks lined up fine. just the front bumper mounting is the only thing we ran across that was diffirent.
Old Jun 20, 2003 | 06:57 AM
bremen242's Avatar
bremen242
differences
curious- did you have to cut the core support for the '95 frame? i was wondering since the front rails on the '95 are "crinkled" up. (at least the f-150 ones i've seen).
I know my 85 & 90 f-250 frames are the same except the front shock mounts and the 90 bumper has a couple different holes on the frame.
