NY's Let Freedom Ring July '13 BS thread
#886
Yeah it is going to be alot of cleanup once it is out Neil. And the county uses alot of LDH for supply lines since most of the county has hydrants. Most units run 5 inch supply lines on their engines as well as some 3 inch and then attack lines are either 1.5" or 2". some units also have reel lines. Most of the companies on the first alarm will have alot of hose to rack up. The 3rd alarm wont have too much to put back on at this point. Their units are back at a staging area and they walk up. Right across the street from teh bldg is a funeral home as well.
#887
#888
#889
On our pumper/tanker we are carrying 900' of 4" LDH, 250' 2.5" preconnected, 200' of 2.5" in a dead lay and two crosslays of 200' 1.75". Our engine is carrying 900' of 4" LDH, 250' of 2.5" preconnected, 300' 2.5" in a dead lay, two cross lays of 250' each, one 100' trash line and another trash line with 150' and foam inductor. The trash lines are 1.75"
#890
#891
#892
#893
Not to far off from what the new county engines have here Neil. For most of the engines the county has 1500 gpm Hale pumps. They carry 750 gallons of water. One of the new engines the put in service about 2 yrs ago now has a 1000 gallon tank because it is in a more rural area.
The engine has a 1250 gpm Hale pump and 1000 gallons water.
#894
#895
Shaun the pictures that I posted in the past of the block fire from a few months ago, that was our pumper/tanker at that call. It is our first out for structure fires, mutual aid calls and fill ins. I will respond as a tanker if needed.
We roll out engine second due on fires, first out for MVA's and any rescue calls.
#897
#898
