WOOD FLATBED BUILD - 3D MODEL AND CONSTRUCTION PLANS
#91
#92
I'm about 6 or 7 hours from Louisville. It took me that long to reach there from Fort Wayne, IN (when I did a 17 hour run to Midway, GA [around Savannah, GA area] in February 2012).
#94
#95
#96
I am from Mt. Washington. Right South of Louisville about 25-30 minutes from downtown. I have heard of Salamander Springs Permaculture farm in Berea KY which ought to be just South of you a little ways. And there is one other one really close teves Faro you I have seen on some YouTube videos, but have lost touch with what they are doing.
I cannot wait to get the KY Chapter involved in truck projects when I get back. I plan to try to be a Chapter leader like Gary, our Local leader here.
When I get back I'll give ya a hollar.
#97
I have family in Carrolton. You live up around there? My wife and I plan on finding land anywhere around Louisville, from Carrolton all the way down to Bardstown. We've even thought of buying land in Indiana where its a little cheaper. But my granny just bought her retirement home in Mt. Washington and my parents know everybody in town there so I don't think I will have any luck getting them to move too far out of Mt. Washington. I will check out that Permaculture farm. Maybe when I get in town we can start up a Ford Truck meet and greet every other month or so.
#98
#99
#100
How thick is the door?
What material is it?
Use a piano hinge?
I would rout a recess so you can install a gasket and still keep it flush with the side.
They sell cheap file cabinet locks that would work well. (you need to find one with the proper depth and latch bar)
Might want to add a cable or chain so it only opens a little more than flat.
The extra space is handy for sorting through what you pull out without having to set it somewhere.
Use a piano hinge?
#101
Use a piano hinge?
Use a piano hinge?
I downloaded a piano hinge and couldn't get it to sit right with the plate.
Great idea on the chain/cable. That using your noodle.
#102
If you routed a groove it would set flat with the side.
If you attached the door to the inside of one leaf of the hinge then the pivot would be in the correct geometry to fully open.
But then you'd either need a hinge with a large space between leaves or have to set the inside leaf level to allow for the door thickness and the screws into the box.
It would be easy to fix this with a metal brake.
I don't think 1/8" is overkill.
I would probably plug weld the door to the hinge through those screw holes and grind them flat.
#103
#104
I think you are trying to attach it flat, on the outside...
Fold it 180* and attach the door to the outside of the hinge.
Or 90* and attach the door to the inside of the vertical and the horizontal to the floor of the cavity.
My suggestion is to have the plate larger than the opening in the side rail.
Maybe 1/2" all around?
..or better, just top & sides if you decide you need to lay the hinge open 90*. that way it is flush with the bottom of the cavity.
This rabbet would be the thickness of the plate+the semi-compressed thickness of some self adhesive weatherstrip tape.
Then, the outside of the door would be flush with or slightly inset to the side of the truck when latched/locked shut.
Farm (ab)use will probably bend it anyhow but there's no reason to have it ready to snag anything that slides past it.
(like your leg when you slide over the side)
