1967 Ford Ranchero Gas Tank
Old 11-07-2013, 11:09 AM
Cantaloupes's Avatar
Cantaloupes
Cantaloupes is offline
I'm currently restoring a 1967 Ranchero and the only part I'm having trouble finding is the gas tank. Does anyone here know where I could possibly find one? Thank you.
Old 12-08-2013, 09:00 AM
lowcountryF100's Avatar
lowcountryF100
lowcountryF100 is offline
I had a 67 Ranchero a few years ago and it had a mustang gas tank. The gas gauge never worked. Hope that helps.
Old 12-11-2013, 03:53 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Many Econoline owners use a Mustang tank. The tanks are larger so longer straps have to be used. The intake needs to be moved from the center to the corner (radiator shop can do this). The Mustang sender works with the Econoline fuel gauge. I assume it should be similar with the Ranchero.
Old 02-14-2014, 10:34 PM
Chuck Fuller's Avatar
Chuck Fuller
Chuck Fuller is offline
My son had a F250 with a fuel tank in the cab. He was having lots of rust problems. We could not find a new tank to go back in the cab, so we put a small piece of chain in it and rattled it around to b rake the rust loose. then we steam cleaned it, and bought some stuff called RedKote from ORiellys. It was like liquid plastic in a can. We poured it into the tank and rolled it around, then let it dry according to the instructions. It formed a plastic tank inside the old metal on and we never had a rust problem again. I hope this helps.
Old 02-28-2014, 10:06 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
^ 1961/72 F100/750 In-Cab fuel tank reproduced by Blue Oval Truck Parts. ^
D0OZ-9002-C (replaced C4DZ-9002-F & G) .. Fuel Tank / Obsolete
1964/66 Falcon Ranchero/Station Wagon / 1966/69 Fairlane & 1968/69 Torino Ranchero / 1967/70 Falcon Station Wagon.
COLLECTORS AUTO SUPPLY in Oroville WA shows 2 = 800-414-4462 .. but may not have any.
At one time, dearbornclassics.com sold a reproduction.
Whitepos72
05-08-2015 03:01 PM
96ford4x4turbodiesel
General Automotive Discussion
05-11-2004 10:49 AM
The Fife
03-19-2004 01:11 PM
OldRed49
04-21-2003 03:15 PM
78bigunns
12-26-2002 09:08 AM
Quick Reply: 1967 Ford Ranchero Gas Tank
