My 96 7.3 quit running. Any help would be appreciated.
Old 06-04-2013, 07:24 PM
abherd's Avatar
abherd
abherd is offline
Hey Roentgeet where is the HPOP res?
Old 06-04-2013, 07:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
here you are:
Old 06-04-2013, 08:04 PM
abherd's Avatar
abherd
abherd is offline
Thank you my friend.
Old 06-04-2013, 08:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
You are welcome. Good luck.
Old 06-04-2013, 08:44 PM
abherd's Avatar
abherd
abherd is offline
Just my stinking luck!!! Batteries have been on low charge for 15 hrs and all I get at the switch is tick, tick. I beat on the starter and still a freaking tick. Must have burn it up yesterday. Going to pick one up tomorrow. If I didn't have bad luck I wouldn't have any luck at all! I'm sooooo pissed!
Old 06-04-2013, 08:52 PM
abherd's Avatar
abherd
abherd is offline
Just to keep YALL informed my first sensor I unplugged to try was the ipr. It was wet insided when I unplugged it then no luck with the starter
Old 06-05-2013, 06:04 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
It won't start with the ipr unplugged. Try the icp unplugged. Doing that can sometimes "unstick" an ipr.
If you get a new starter, you can get a starter for a 99-03 super duty 7.3. They are only 2 bolt starters, not 3, but bolt right in. They are a gear reduction starter that work better. The eyelet on the small wire will need to be egged out if you go this way, otherwise it bolts right in.
Old 06-10-2013, 07:11 AM
abherd's Avatar
abherd
abherd is offline
Ok Guys, Going to pick up my new starter. Finally I have a day to work on my truck. When I get it bolted up, going to start off trying to start with the ICP unplugged. If anyone has a next step to do please feel free to post what to do next if it doesnt start with it unplugged. I will check back on here when I get my starter bolted on. Sorry for the delay. Not much time here with work and my son playing Travel Baseball every weekend. Thanks for all and any help.
Old 06-10-2013, 09:53 AM
abherd's Avatar
abherd
abherd is offline
Ok Guys, Just installed my new starter and it turns over like a champ. I unplugged the ICP. Still no fire or no smoke from the tail pipe. When I unplugged the ICP it was very wet inside the plug. I sprayed some brake clean in the plug side to dry it out to make sure it wasnt crossing over. Checked rpms while turnning over and rpm guage goes up to 100 rpms and stays while I am trying to turn it over then returns to zero when I release the ignition. Any Suggestions? Does anyone have a pic or anything on the fuse boxes to tell what fuse goes where. Thought about trying to unplug the bowl heater but dont know what fuse it is.
Old 06-10-2013, 10:12 AM
abherd's Avatar
abherd
abherd is offline
Just checked the HPOP Level and it is full to the top. Just keeping you updated on everything I am doing. Also found the bowl heater fuse and unplugged it. Still no fire and no smoke.
Old 06-10-2013, 11:33 AM
madpogue's Avatar
madpogue
madpogue is offline
Was the ICP connector wet with oil, or water?
Old 06-10-2013, 11:38 AM
abherd's Avatar
abherd
abherd is offline
It looked like it was wet with oil. I sprayed some break clean on the plug and let it dry before I tried to start it nd still no fire with it unplugged.
  #28
Old 06-10-2013, 11:45 AM
427 fordman
I hope you unplugged the bowl heater and not the fuse. The fuse runs the pcm too, it will never start that way. I'm leaning towards your ipr as the main problem, you could pull it and dissassemble it to try and clean it for a TEMPORARY fix (works sometimes, but sometimes doesn't) but the icp needs replaced too if it was all wet with oil. If you pull the ipr you'll need an oring kit for sure to reinstall it. If you do this and after the cleaning it runs, I wouldn't go long without getting a new one.
One more thing you could check if you haven't is pull the idm and shake it to see if it has water in it.
  #29
Old 06-10-2013, 12:39 PM
abherd's Avatar
abherd
abherd is offline
Hey 427 Fordman, No I did unplug the fuse. Where do I unplug the heater bowl? Is the ipr under the icp? not the plug that goes into the hpop right? Also where is the idm so I can check it? Thanks for helping.
  #30
Old 06-10-2013, 01:46 PM
Furniture Doctor's Avatar
Furniture Doctor
Furniture Doctor is offline
Fuel bowl wire
Tghere is a wire that connects to the heater bowl. I believe that it is the lower wire. I have had mine unplugged for more than a year now.
Doc
Quick Reply: My 96 7.3 quit running. Any help would be appreciated.
