My 1984 F-350 rustbucket - getting it road ready
Old 05-30-2013, 08:02 PM
astembridge's Avatar
astembridge
astembridge is offline
Originally Posted by Gary Lewis
So, if you are going to use the truck I recommend fixing the brake system, meaning replace the M/C, calipers, and wheel cylinders.
I was thinking along the same lines. Picked up about $350 in parts today:
Power booster
Master cylinder
Front brake hoses
Front calipers
Rear hose
Rear wheel cylinders
Haven't taken off any wheels yet, just got the old booster & MC out tonight. I'll start with the front end and will see what the discs look like. May go ahead and replace the pads since those are low cost. Hopefully the discs are OK ($70 ea).
I also need to replace the emergency brake cable or fix it somehow. It has about 4" of play and is useless right now.
I hope I'm not throwing good money after bad fixing all this. Still have a steering joint/shaft to replace, and eventually a lifter issue in the engine. The cab has plenty of rust on the back corners but thankfully not so much on the frame underneath. I know I'm never going to get my money back out of this.
Old 05-30-2013, 08:55 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
The rotors have a lot of meat in them and, in my experience, can be turned. As can the brake drums. Put pads and shoes on and you'll have a new brake system - after you find and fix the leak, assuming the hoses aren't it.
Old 05-30-2013, 09:35 PM
fellro86's Avatar
fellro86
fellro86 is offline
It all depends what you got the truck for. If you want it to do work for you, it could well do that for years to come. If you wanted a pretty play toy, probably not as easy to get the value back.
Sounds like the e-brake cable is sticking, best thing to do there is replace it. They generally don't run that much, $20 a side.
Old 05-30-2013, 10:53 PM
astembridge
Are there any how-to's on replacing calipers and rebuilding rear drum brake assembly? I've googled and tried searching here but only find articles on newer or older trucks. I have the dually rear wheels if it matters.
Old 05-30-2013, 10:54 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
autozone.com has a decent auto repair manual section. You need to create an account but access is free.
Old 05-31-2013, 06:47 AM
astembridge
I've been trying to access the content but clicking any section returns:
Sorry, we experienced a technical problem while trying to retrieve this information. Please try again soon.
Tried Firefox and Chrome.
I was hoping there would be a post here that had some pics and explanation. It looks like it will be a little harder to do than on my Mazda/Ranger small truck.
Old 05-31-2013, 08:54 AM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
Unfortunately, I'm not home, but there is a pretty good section on my website with the F-250/350 drum brakes. it is under the 1991 section. Before I yanked anything apart, I would put enough fluid in the MC you can pump it until the source of the leak becomes evident. You are dealing with roughly 30 year old steel lines.
If you go to my thread here: https://www.ford-trucks.com/forums/1...n-86-f350.html there are some pictures where I replaced all my brake lines. I had a failure one weekend while at a campground with our 30ft 5th wheel. It was the portion of the lines running across the crossmember behind the rear axle.
Last edited by 85lebaront2; 05-31-2013 at 08:56 AM. Reason: Added location for brake information.
Old 06-02-2013, 06:34 AM
astembridge
Is anyone else able to access the repair guide section on Autozone?
| Repair Guides | | AutoZone.com
I've logged in and get a red error box if I click any of the component sections (brakes for instance).
Wondering if it's a site problem or my browser/OS.
Old 06-02-2013, 06:51 AM
bashby's Avatar
bashby
bashby is offline
I can access them
Old 06-02-2013, 07:06 AM
astembridge
I'm getting desperate for some help. I ordered the ALLDATA online manual for a 84 F350. At least I used a coupon code in advance and only lost $15.
For anyone else reading this - do not waste your money. They do not have information for brake repairs.. only prices and labor times. In fact they have very little information for this car.. alignment was there, but the images are so small it is a joke.
Old 06-02-2013, 07:07 AM
astembridge
Originally Posted by bashby
I can access them
It must be my system thanks.
Old 06-02-2013, 07:13 AM
astembridge
Found this 1984 Ford F350 Remove the Caliper - WikituneUp - The Free Service Manual
Haynes explains it different, says I have to bend tabs while prying with a screwdriver at the same time.
Surely there is a definitive guide on how to do this without breaking something. I'd be glad to write one up myself with pictures if I could just figure it out.
  #28
Old 06-02-2013, 07:29 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
If the 84 is the same as 81 I can post pictures from my factory shop manual later today.
  #29
Old 06-02-2013, 07:48 AM
astembridge
Let me snap some photos of what I have -- give me a few minutes.
  #30
Old 06-02-2013, 08:18 AM
astembridge
From top
From front/back:
From front/bottom:
Quick Reply: My 1984 F-350 rustbucket - getting it road ready
