75 Highboy Resto-Mod Build
  #106
Old 10-29-2013, 10:50 AM
TylerJ150's Avatar
TylerJ150
TylerJ150 is offline
Originally Posted by 99longhorn
Subscribed lol
Welcome over lol
  #107
Old 10-29-2013, 11:28 AM
99longhorn's Avatar
99longhorn
99longhorn is offline
Originally Posted by TylerJ150
Welcome over lol
Lots if good stuff on here lol
  #108
Old 10-29-2013, 11:30 AM
TylerJ150's Avatar
TylerJ150
Yeah for these trucks there's more info than the f150 forum
  #109
Old 10-29-2013, 09:04 PM
TylerJ150's Avatar
TylerJ150
Shaved my emblem holes
Started saving the vin decal they painted over, I'm kinda excited to see what's below
  #110
Old 10-30-2013, 09:05 PM
TylerJ150's Avatar
TylerJ150
Soooo turns out my cab is off a 77, and I think an F150. The GVWR is like 6000lb, I thought the F-250's had higher
  #111
Old 11-04-2013, 10:35 PM
TylerJ150's Avatar
TylerJ150
Finished filler work on my door pillar and primed it, then remounted the door, and mocked up my fender
  #112
Old 11-06-2013, 03:18 PM
TylerJ150's Avatar
TylerJ150
Fixed my floor pans
Also stripped the pillar and shot it with some primer.
  #113
Old 11-07-2013, 12:37 PM
fordcrzymike's Avatar
fordcrzymike
fordcrzymike is offline
Looking good! keep chugging along! What did you do to fix the floor pans?
  #114
Old 11-07-2013, 03:41 PM
TylerJ150's Avatar
TylerJ150
Thanks, chopped the old metal out and bent and shaped a new one to fit in place. Had to actually replace part of both layers, but I shot weld through primer in between so as to not let the bare metal rust again. Finished shaping out my glass today and shot it in etching primer. The only indication it's been messed with now is the lack of a drain hole.
Floor chopped out
Bottom layer fixed and primed
Upper metal welded in
Shot in primer
Today's little project...
I really think it cleans up the side profile, and makes the head on view more symmetrical. Plus I couldn't ever get mine to sit at a 90* angle
  #115
Old 11-10-2013, 03:00 PM
Hyperactive460's Avatar
Hyperactive460
Hyperactive460 is offline
looking good there kid, keep up the good work .
  #116
Old 11-10-2013, 05:34 PM
TylerJ150's Avatar
TylerJ150
Thank you! Should start really knocking out the filler work and such this week.
  #117
Old 11-12-2013, 07:22 PM
TylerJ150's Avatar
TylerJ150
Well, as you guys may know, things on these trucks don't always go just like you plan them. Found some rust in the passenger floor pan, which I have patched, just have to fill it now. The big issue was when I sat back and looked at the back cab corner, I noticed the body line goes uphill towards the front. So I stripped the paint off and found, like I suspected, a crappy rust repair, so now it looks like I'll be re aligning the door perfectly and then bringing that pillar FUBAR back to standard.
Floor patch, just need grinding and fill work.
The old crooked patch that's going away.
Also did some R&D at the salvage yard today since I was there with a buddy, you can see where this is going
  #118
Old 11-13-2013, 01:18 PM
fordcrzymike
I always wanted to add a cargo light to my truck (never had one since it's only a custom). I was just going to buy one from LMC probably, but I like the idea of adding a 3rd brake light also. I'm interested to see what you do, so be sure to keep us up to date. What other rust repair do you have left? I see that you still have the rear fenders to do, anything else? I want to see paint in this truck!!!
  #119
Old 11-13-2013, 03:01 PM
TylerJ150's Avatar
TylerJ150
Well the floors are finished now, at least the front is. I know there's a couple holes behind the seat from screws that need fixing, but they can be welded.
Next week I'll be tackling that screwed up cab corner, and the week after that I'll knock out the cargo light and third brake light. Im trying to find a new bed because i can do mild rust repair on a cheap enough bed for what it'll cost me in parts and materials to fix this one. Going to go with a white LED one, and paint the edges black so it mimics the look of stock, but has the added function and cool factor.
A true dent person should notice it right away, but it'll leave others guessing, and I love those things that make people do a double take and scratch their head lol
  #120
Old 11-16-2013, 09:15 AM
Hyperactive460
so what was the verdict on this discovery ?
Quick Reply: 75 Highboy Resto-Mod Build
