Trying to find some info on a bolt
Old 05-27-2013, 07:06 PM
obscurity's Avatar
obscurity
obscurity is offline
Question Trying to find some info on a bolt
On my rear axle there is a brass fitting that connects the rear brake lines with the line going to the master cylinder. It is bolted to the axle. In my case the bolt has broken off but it appears to have been hollow Is this normal. I should mention that I have a Dana 60 axle (I think). The bolt is numbered 4022 in the attached image(upper left area). I have not been able to find this bolt for sale and I don't know if there is anything special about it. Any thoughts are appreciated.
John
Old 05-27-2013, 07:12 PM
Marty Smilt's Avatar
Marty Smilt
Marty Smilt is offline
I am pretty sure that the bolt was also the vent for the diff. Try to get a left hand drill bit and drill the bolt out. Hopefully it will grab at some point and come out.
Old 05-27-2013, 08:09 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Pick one up at a junk yard. It is hollow and probably had an extension where a hose attached. It is the vent for the differential and the attached hose should be fastened high up on the frame of the truck, the higher the better. You want the vent higher than any water you may get into
Old 05-27-2013, 08:27 PM
teardropty's Avatar
teardropty
teardropty is offline
Mid-fifty has the bolt for sale. Napa also carries them.
Old 05-27-2013, 08:40 PM
Jim 54 panel's Avatar
Jim 54 panel
Jim 54 panel is offline
Part # 1336 in the Mid-Fifty catalog
Old 05-27-2013, 09:01 PM
obscurity's Avatar
obscurity
The Mid Fifty part is pretty much what I was looking for. Just curious if anyone knows a part number for one with a barbed hose fitting? I don't plan to drive the truck in water much but in Atlanta any rain can lead to a flood.
Thanks for the help,
Old 05-27-2013, 09:10 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Slide a piece of fuel line over the fitting and a clamp if necessary. No pressure involved other than atmospheric.
Old 05-28-2013, 09:21 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Look for a 4X4 axle vent.. The 4 wheel drives have the tubes with a vent on top.
BJ
79 shortbed lover
12-16-2010 09:44 AM
Swatter
09-04-2009 06:39 PM
ranger714
1983 - 2012 Ranger & B-Series
03-23-2007 05:24 AM
Skandocious
02-23-2007 09:19 PM
Quick Reply: Trying to find some info on a bolt
