timing chain slack
Old 05-10-2013, 12:15 PM
riverguideguy's Avatar
riverguideguy
riverguideguy is offline
timing chain slack
how much slack is ok? i was watching my rotor while i turned the crank and the timing marks on my balancer moved 6 degrees before the rotor moved. is this ok or time for a new chain? thanx
Old 05-10-2013, 01:16 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
You're ok, for the time being anyway...6 degrees equates to roughly a 1/4" of chain deflection.
Were it 10 degrees or more (1/2" of chain deflection) than it would warrant immediate replacement.
But of course there's no harm in replacing the chain now if you're so inclined.
Old 05-10-2013, 03:20 PM
Dasher400's Avatar
Dasher400
Dasher400 is offline
[quote=montana_highboy;13148765]You're ok, for the time being anyway...6 degrees equates to roughly a 1/4" of chain deflection.
I am feelin ornery today so I gotta ask, how the heck did you come up with that conversion?! Not trying to be a jerk, seriously. Especially to a another Big Sky country Ford dude.
I am just not smart enough to figure that sort of linear deflection derived from rotational variance.
Good advice by the way, I'd replace it too.
Old 05-10-2013, 06:13 PM
montana_highboy
If such a mathematical formula exists that can figure out that equation it's above my head.
I was just using personal experience as the basis for my "math", having torn down my fair share of tired old FE's i know that 5 degrees slop at the balancer generally equates to 1/4" slop at the chain...10 degrees slop at the balancer = 1/2" slop at chain, so on and so forth...short of tearing the front of the motor down it's a pretty painless way to get a fairly accurate estimate on chain wear.
Whereabouts in MT. are you located?
Old 05-10-2013, 08:28 PM
riverguideguy
thanx montana ill prolly just let it ride for now. the timing doesnt jump around when i put a timing light on it. plus the crank was really hard to turn even with a 2 foot breaker bar so it was hard to stop putting force on it exactly when the rotor started to move so im thinkin its prolly more like 4 degrees slack.
donerico
01-26-2017 02:13 PM
nk_andr
02-03-2007 01:39 AM
Ken H
16
09-28-2006 11:10 AM
bluene
12-30-2004 09:44 AM
ford390gashog
01-19-2004 12:53 AM
Quick Reply: timing chain slack
