Offroad & 4x4
2 ? in 1 post
Old 05-01-2013, 07:18 PM
Dixieland Diesel's Avatar
Dixieland Diesel
Dixieland Diesel is offline
2 ? in 1 post
I have a 92 f250, I converted away from the spicer 50 twin traction to the Dana 60 straight axle. I was told a reverse shackle kit would raise my front end 4 extra inches... anyone have experience in this? Also am having trouble finding leaf springs with over 6 inches of lift... question 2 on my 98 ranger the four wheel drive high and low dash lights blink 6 times every couple of minutes, anyone ever have this? The ranger wont shift into 4 wheel drive either... any knowledge is greatly appreciated!
Old 05-01-2013, 07:45 PM
77mud's Avatar
77mud
77mud is offline
why do you need more than 6" of lift?
Old 05-01-2013, 08:27 PM
Dixieland Diesel
I have approximately 6 inches of lift now, if the reverse shackle for the front indeed does raise the front I would like to replace the rear springs to level the truck back out. Plus my goal is to run 46in XMLs
Old 05-01-2013, 08:59 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
I cannot contribute information to this
Old 05-02-2013, 05:18 AM
Dixieland Diesel
dont like the tire or dont like the idea of lifted trucks?
Old 05-02-2013, 07:22 AM
alpha/omega
Far, far from it. Especially when done correctly and for the right reasons
Let me guess...
This is you DD and you are still in highschool
Old 05-02-2013, 01:50 PM
fatdan460's Avatar
fatdan460
fatdan460 is offline
i'm also guessing floriduh, alabama, or georgia resident as well......just a guess
Old 05-02-2013, 04:37 PM
bigcountry62's Avatar
bigcountry62
bigcountry62 is offline
Can you say "pavement ****"
Old 05-03-2013, 11:42 AM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
You do realize how much those tires weigh a piece, don't you? I'm guessing you are getting a "good deal" on them? What kind of gearing are you running? Motor/tranny? Any upgrades like axleshafts or U-joints?
Old 05-03-2013, 04:35 PM
77mud's Avatar
77mud
77mud is offline
Im gonna go out of a limb and say a diesel...
Old 05-05-2013, 11:44 AM
Dixieland Diesel
its 4.11 gears right now, but i am moving up to 5.38 gears when i get the tires. yes i am getting a good deal. still have nipples on the 46s for 200 a piece. its not my daily driver, its a recovery vehicle. i am in florida, and far from in highschool. is this a meet and greet or is this the forum for asking questions and getting answers? i dont know everything thats why i am asking. its a 7.3 with an e40d upgraded, freshly rebuilt with a lifetime warranty. any other questions about the truck or could someone tell me what they would do differently?
Old 05-05-2013, 01:52 PM
77mud's Avatar
77mud
77mud is offline
Better invest in upgraded parts for those Axles while your at it because your gonna be snapping axle shaft's and axle joints like crazy if they are stock turning that much weight, pretty sure they are a good bit heavier than Bogger's or something that would pull twice as good.
looks like for getting enough lift to clear 44-46" tire's is gonna require some fabricating skill's
This may get you a little more lift for the front, if you do a shackle reversal for the rear end you should net a couple inch's aswell
OBS RSK SD Spring Hanger Conversion Kit
Old 05-05-2013, 02:05 PM
Dixieland Diesel
so with the OBS RSK SD Spring Hanger Conversion Kit i would change my leaf springs to super duty leafs?
Old 05-05-2013, 02:18 PM
77mud's Avatar
77mud
77mud is offline
looks like those tires weigh 220-225# a piece with out a rim... thats a hell of a lot of rotating mass
Old 05-05-2013, 02:21 PM
77mud's Avatar
77mud
77mud is offline
From the description...
To develop this kit we worked closely with the people that matter the most, you guys! This was the first kit on the market to offer a complete bolt on RSK (reverse shackle kit) to use the Superduty springs on the OBS (old body style) trucks that required no frame or bumper modifications.
With this kit, you can bolt on our conversion hangers using existing holes in your frame and clear all factory bumper mounts and components. For trucks that are wanting to install an intercooler, we have designed the kit with optional bolt locations to allow proper clearance for most intercoolers. For this installation configuration, you will need to drill two additional holes per side.
The installation of this RSK kit will provide a noticeable improvement in ride quality. This is accomplished through the use of a longer Superduty spring and the relocation of the shackle to the rear of the spring. With that change, the truck is no longer fighting against itself when it hits bumps on the road. Instead, you will have a truck the drives and handles like a 1999-2004 F-250/350.
The kit is available in 3 different lift heights. This is the lift amount of the kit itself. Please keep in mind that depending on what code of Superduty springs are used, you may have additional lift amount. The kit comes complete with the front hangers and rear shackles and all needed assembly hardware. Superduty springs and spring eyelet bolts are not included.
Quick Reply: 2 ? in 1 post
