Engine/tranny swap question in 78 F100
Old 04-27-2013, 04:08 PM
grandads76's Avatar
grandads76
grandads76 is offline
I have a 78 F100 with a 460/C6 setup. The guy that my dad bought it from built it for bracket racing so you can only use 93 gas and get less than 10 mpg. I have a friend with a really nice 302/C4 from the 70s. I don't know what it originally came in.
My question is what obstacles will I be facing in this swap? I'm mostly concerned with the driveshaft and whether it will work. What other problems are there?
Thanks for your help!
Old 04-29-2013, 09:09 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
The 460 is fun. I'd keep it. I have one in my 77 shortbed.
If the truck had the 460 from factory, or a 302 351w from factory, then the 302 will bolt in with stock 78 truck motor mounts. A trans crossmember in the truck now may be able to be moved so it will work. It only bolts in so a few more holes and you're done. The c4 came in some of these trucks but they were the "heavy duty" sorta, pan fill trans. Don't worry if its from a car. The crossmember and trans mount are virtually in the same place.
If the truck had a 351m and the 460 is using swap mounts, then you'll need to locate a set of 302/351w frame mounts.
Driveshaft is different. The c6 is longer and uses a different slip yolk.
Redneck Romeo
18
09-08-2012 05:20 PM
73FOMO
08-15-2012 09:05 PM
viol8r750
Engine Swaps
06-01-2010 07:44 PM
hot_bod_247
09-15-2009 07:24 PM
PA79F150
07-04-2002 11:37 AM
Quick Reply: Engine/tranny swap question in 78 F100
