Will this work?
Old Apr 14, 2013 | 12:47 PM
tjbargstadt's Avatar
tjbargstadt
Will this work?
I have a 87 bronco that is off road only, I also have a set of rears out of a 86 f350 I was wondering if I could keep the housing in the bronco and swap the knuckles, axles, center section from the 350 to the bronco
Old Apr 14, 2013 | 12:58 PM
JayzDaddy's Avatar
JayzDaddy
Unless your bronco has the same axle as the 350 the answer is no.
Old Apr 14, 2013 | 02:30 PM
tjbargstadt
The axles are different but I thought since I would be changing everything but the housing from the 350 it would work since the housings look the same
Old Apr 14, 2013 | 02:42 PM
JayzDaddy's Avatar
JayzDaddy
They have different axle numbers and names because they are different. Different total width, shaft size, carrier size, pinion shaft size and depth, c clip or not. Lots of variations.
It would help if we knew what you have in your bronco now for and axle. The 350 is probably a dana 60. Not to mention the gear ratios are probably different.
Old Apr 14, 2013 | 05:16 PM
tjbargstadt
The bronco has a 44 and the 350 is a 60 with 4:10's I have the matching rear rear I plan to use I was just thinking it may be better for me to swap everything from the 60 to the 44 rather then trying to make the 60 fit the coil spring set up in the bronco. Basically I just put a built motor in the bronco and want to run bigger tires therefore I need stronger axles but I'm on a tight budget and have the rears laying around so I was hoping for an easy way to make it work
Old Apr 14, 2013 | 08:14 PM
JayzDaddy's Avatar
JayzDaddy
No matter what you did the 44 is still gonna be a 44. 35s are about the limit if you use the truck. It'll break with 35s if you really use it.
Best bet is swap front and rear 60s in. You do that 44s would be no sweat
1976 ranger
1966 - 1977 Early Broncos
Aug 15, 2007 12:00 AM
loudfords
Apr 23, 2007 08:55 PM
80Bronco94
Aug 20, 2004 11:51 PM
blackrhino
Dec 14, 2003 11:43 AM
elwhoppo
Bronco II
Nov 15, 2002 11:01 AM
