2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2010 Headrests suck - need replacements
Old 06-28-2010, 06:18 PM
EXPY2010's Avatar
EXPY2010
EXPY2010 is offline
The 2010 driver/passenger headrests are bent forward way too much. I know they say its a safety factor for whiplash but it is terribly uncomfortable.
Why drive for years in discomfort for the chance you might get rear ended.
You cannot sit with a proper posture with these headrests, no exaggerating. My back is always hurting during and after driving.
Any headrests on the after market I can use or maybe the headrests of another yr EXPY?
Thanks!
Old 06-28-2010, 06:51 PM
berry1234's Avatar
berry1234
berry1234 is offline
2007 are the least tilted.
Old 06-29-2010, 12:44 AM
EXPY2010's Avatar
EXPY2010
EXPY2010 is offline
Is there a site to buy them online?
Old 06-29-2010, 05:40 AM
chuck s's Avatar
chuck s
chuck s is offline
While you're looking recline the seat a couple of notches. If too upright the headrests smack you in the back of the head. These are still rods inserted in the seats I assume? Reforming the angle should work.
-- Chuck
Old 06-29-2010, 10:31 AM
berry1234's Avatar
berry1234
I would probably try to buy it at a local dealer. There is a small chance they have changed the design of the replacement 07 headrests to match the 2010's pitch. Also might be worth it to take one out and take it to an upholstery shop and see if they can bend it a bit or replace the bars.
Old 07-03-2010, 07:37 AM
blackout150's Avatar
blackout150
blackout150 is offline
I took mine out and put them in backwards. They were making my neck hurt and I had to recline the seat too far back to make the headrests comfortable.
Old 07-06-2010, 02:59 PM
rjd75's Avatar
rjd75
rjd75 is offline
Here is the solution to the headrest problem..
Tools required
2 people
2 pieces of cardboard
one small piece of plywood
one 2ft length of square or round pipe just big enough to fit over headrest pole
Instructions
1. Remove headrests
2. place one piece of cardboard on the ground
4. place headrest on cardboard
5. cover head rest with second piece of card board
6. place plywood on top of headrest
7. have one person kneel on the plywood to hold the headrest in place
8. have the other person slide the pipe over the pole and bend it down about 1/2" or as desired
9. reinstall head rest and enjoy your 2010 expedition
Old 07-07-2010, 09:40 PM
johnkn's Avatar
johnkn
johnkn is offline
I have a feeling that your solution may change a bit when the 2011's come out with DVD screens built into the back of each headrest.
Probably need to then deconstruct them, bend the bars and reconstruct. That may then make the angle of the screen wrong. It's always something.......
Old 07-19-2010, 12:42 PM
Harleyrider206's Avatar
Harleyrider206
Harleyrider206 is offline
2010 Head Rest
Thanks to rjd75 easy fix to make the headrest comfortable.... safer then turning the headrest backwards ....Happy Trucking
Old 07-19-2010, 12:43 PM
Harleyrider206
2010 Head Rest
Old 02-12-2011, 10:47 PM
edycri's Avatar
edycri
edycri is offline
Just replace them with Navigator headrests.
Old 02-15-2011, 03:21 PM
berry1234's Avatar
berry1234
Why spend that much cash? Someone just offered a free solution.
Old 02-15-2011, 04:10 PM
edycri's Avatar
edycri
edycri is offline
You can get them for cheap just have to search around a little. If you want to take a chance in breaking one of the bars or both while trying to bend them then you should go with his solution.
Old 02-16-2011, 10:25 AM
rjd75's Avatar
rjd75
rjd75 is offline
Unless you are King Kong I say the changes of breaking them using this method are slim to none..
Old 02-16-2011, 10:41 AM
berry1234's Avatar
berry1234
This is the strangest logic I have ever seen.
'why take a chance at breaking them' - why does this matter if you can get them for 'cheap'?
Why not attempt to fix what you have for free THEN if it breaks you buy them for 'cheap'.?
Quick Reply: 2010 Headrests suck - need replacements
