yup. I see what you mean. moved to a windows laptop and just see the boxes. It's a icon library that shows up on the phone as an alternate keyboard. has a couple hundred little avitars and symbols. I guess it only works on apple stuff. would have been fun here.
It is going into the shop tomorrow.
So far they are doing: Head gaskets, studs, egr cooler, oil cooler, blue spring, rail plugs, HPOP's STC, turbo drain pipe, fumoto valves on the block drains, scoop in the up-pipe...
Can you think of any thing else?
I'll probably take pictures if you have any requests, as they are pulling the cab....
Sounds like you're on it! I would suggest the Ford head gaskets. Quite a few repeat repairs on the black onyx gaskets but the shops push them because it save $$. There are some others out called black diamond they have the black sealing compound also but it's printed onto the gasket like the ford ones. Jury is still out on those but I would be concerned.
Ford head gaskets, ARP studs, Sinister EGR cooler (Would have gone with Bullet proof, but they were $200 more for no good reason), Ford Oil cooler, Green anti-Freeze with aditive.
That's wild. I can see them. Posted on my IPhone and looking at it in a iPad without the icon app installed now.
Originally Posted by fabmandelux
I'm on my desktop, and only see 9 small box's...
