78 150 351m to 460 help
Old 02-25-2013, 07:12 PM
inhonorofchuckgehner's Avatar
inhonorofchuckgehner is offline
I have a 1978 f150 4wd that came with a 351m from my uncle who bought it new in 78 and left it to me when he passed a couple years ago. I am doing a frame off resto. I have the frame painted and is ready for a 4" lift. I want to put a 460 in the truck and I'm wondering if I need to put more than 4" lift springs in the front. I also want to make sure that my c6 and torque converter will bolt up to the 460. I plan on getting the L and L engine brackets. I will save for the fender well exit headers. Can someone break it down for me in a list of things I need to either buy or make that differs from the 351m to make my swap easier. I am 26 and this is my first build so any help is greatly appreciated!!!
Old 02-25-2013, 07:25 PM
Ducky F150's Avatar
Ducky F150
Ducky F150 is offline
id go with a 351 cleveland if you can find one the 460 is kinda limited on what you can do with them and its a tough engine good for a 4x4
Old 02-25-2013, 11:13 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,618 Likes on 1,319 Posts
Sorry, going to disagree with you and say the 351c would be a poor choice for the OP. Bell pattern is SBF, not 335/385 like the 351m/400 & 460, so he needs a new trans. Also, where did you get the idea a 460 is limited?
As for the OP, FWIW, consider just making it a 400 with some compression, headers, intake etc. Less fooling around with cooling, mounts, all the little stuff, and 100lbs less on the front end.
Read this if you haven't already:
TMeyer, Inc. Precision Automotive Machining
As for the 460 swap, very popular. Like I said, cooling, accessory drives, mounts, exhaust, front springs, linkages.
Eye-glazing discussions:
https://www.ford-trucks.com/forums/1...-460-swap.html
https://www.ford-trucks.com/forums/1...ific-info.html
https://www.ford-trucks.com/forums/2...swap-help.html
mario9272
04-02-2014 07:40 AM
vinf100
1978 - 1996 Big Bronco
10-02-2011 09:28 AM
btucker
Engine Swaps
13
04-17-2006 06:41 PM
bajascott
08-23-2004 07:36 PM
Leadfoot
07-15-1999 01:33 PM
Quick Reply: 78 150 351m to 460 help
