No more fuel bowl!!!!
  #31
Old 02-26-2013, 03:24 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
Originally Posted by FI460
Sounds like a good spot for the coolant filter to me, but I'm the definition of amateur hour though. Haha.
I just hit 500 posts a few days ago. Great feeling, huh?
Kind of... except people keep telling me how old I am so I'm not sure being "elder" is working for me. lol
  #32
Old 02-26-2013, 11:09 PM
Redneckmorton's Avatar
Redneckmorton
Redneckmorton is offline
So here are a few pics of the kit as it came.
Everything labeled as to where it needs to go, with connectors already on.
Getting ready to work.
Before
After. Ignore the IPR Wiring. I plan on re doing it.
They don't hang down to much
Not a fan of how close the hose is to the Transfer case, but only place I could mount it with the mounting plate they provided.
  #33
Old 02-26-2013, 11:29 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
That looks a lot better then Irate.
  #34
Old 02-27-2013, 05:05 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
Looks great Daniel. Wish I would have done that. Well done, I hope it works well for you. Thanks for the pictures.
  #35
Old 02-27-2013, 09:21 AM
mjunk1's Avatar
mjunk1
mjunk1 is offline
That is slick and doesn't hang down near as far as I thought... guess I'll have to put one on the wish list!
  #36
Old 02-27-2013, 01:40 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Looks really nice!
Not bad on the price either.
What way did you do it?
Do you have a link to ur thread? and does that thread have pics in it?!
  #37
Old 02-27-2013, 04:56 PM
nbl346's Avatar
nbl346
nbl346 is offline
Would you mind sending me those instructions? I did efuel last fall and currently have the pump wired up to just a keyed relay. My kit came with an oil pressure switch with 3 terminals for the port down by the filter, but i wasnt sure on how to wire it up. Would like to get it on when the weather breaks.
  #38
Old 02-27-2013, 05:36 PM
427 fordman
Originally Posted by Awitte58
Looks really nice!
Alex, my ongoing thread of Trucks in the shop for winter work has pictures scattered around in it. Probably be a pita to find everything. I basically copied TJ BEGGS efuel thread, but went with the strictly diesel wiring harness. However I started gathering parts before he had a parts list up, and I spent WAY too much time getting all of my fittings rounded up. Besides that, I'm real close to spending as much as Daniel did for a complete setup. I'm not sure if the system Daniel got can be used with bio-diesel, if not, that is probably the only thing mine has over it.
  #39
Old 02-27-2013, 06:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Thumbs up
Originally Posted by mjunk1
Makes sense - but I might give it a go for the coolant filter and bypass oil. I'd have to think through how big a mess that would really make! Since both are bypass and would be at "high" spots you would think stuff would drain out pretty well leaving just the fluids in the filter to contend with for a mess. Maybe I'll start with coolant and see.
PS - 500th POST!
Congrats to both of you for your 500+ posts. Well done.
  #40
Old 02-27-2013, 06:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
One question to all:
Is it possible to install the filters horizontally? any contrs? Pros: not hanging.
  #41
Old 02-27-2013, 09:12 PM
Redneckmorton
Yeah. Pm me your email and I will.
  #42
Old 02-27-2013, 11:07 PM
ReBilld's Avatar
ReBilld
ReBilld is online now
Looks good Daniel! Nice job! I've talked to Bar None and I will be getting this kit as soon as I have the funds.
  #43
Old 02-28-2013, 08:50 AM
Redneckmorton
Good deal. Its an easy kit to install. I'm sure it'll go quicker on a stock height truck. With the lift and big bumper. I was having to do a lot of climbing, but its a give and take cause the bumper makes it nice while working in the engine bay.
Tell them I sent you. not that it'd do you any good though.
  #44
Old 02-28-2013, 08:52 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
BUMP
  #45
Old 02-28-2013, 09:00 AM
mjunk1's Avatar
mjunk1
mjunk1 is offline
I'll be right behind you! I finally did my fuel pump and basket rebuild last night. Took 5 hours plus cleanup (you have no idea how good that is for a hack mechanic like me! I dropped both little check ***** in my incredibly messy garage and found them immediately! That NEVER happens to me). Started with the engine really warm and by 2am when I closed the hood and it was 30 degrees, I was pretty cold! Lol. But let it sit overnight plugged in and then cranked it up this morning. No more leaks and everything ran great.
BUT, if it ever goes out again, I'll be looking for the efuel system for sure. Or if I just happen to have a windfall of cash!
Quick Reply: No more fuel bowl!!!!
