Tach sensor
Old May 31, 2003 | 05:31 PM
plumberbt's Avatar
plumberbt
Question Tach sensor
96 Ford Ranger 2.3 L 4 cyl.
Where is the tach sensor?
Thanks
Bart
Old May 31, 2003 | 05:39 PM
Bob Ayers's Avatar
Bob Ayers
Tach sensor
There is no tach sensor. There is a crankshaft position sensor
that gives the PCM information to fire the plugs (ignition), and
fuel injectors. The tach signal is also generated from the PCM.
Old May 31, 2003 | 05:43 PM
plumberbt's Avatar
plumberbt
Tach sensor
thanks...I am trying to hook up a tach. I need to know where to connect the green wire.
Old May 31, 2003 | 06:32 PM
Ken00's Avatar
Ken00
Tach sensor
A tan/yellow wire is the wire for the tach, I bet it already wired for it.
Old May 31, 2003 | 06:43 PM
plumberbt's Avatar
plumberbt
Tach sensor
this truck did not come with factory tach, im adding an after market. Im trying to find out where i can find and connect to this illusive tan and yellow wire
Old May 31, 2003 | 06:47 PM
Ken00's Avatar
Ken00
Tach sensor
It should run from the PCM to the instrument cluster.
Old May 31, 2003 | 07:42 PM
plumberbt's Avatar
plumberbt
Tach sensor
Thanks guys for all your help. I finally found that wire you told me to look for. It works GREAT!
