EEC interchange
Old Feb 2, 2013 | 08:50 AM
davetrydahl's Avatar
davetrydahl
EEC interchange
I hsve a computer out of a 1993 F350 that has the following information:
F4TF-12A650-AHA. Does this information matter or could an alternative computer be used. I was informed that there are none of these available and I would need to get mine rebuilt at the factory. I live in the Bahamas so none of the emissions stuff really is needed and it is a manual shift unit with the basic 5.8 engine. Is there a standard computer I could use to replace this one?
Old Feb 2, 2013 | 09:25 AM
subford's Avatar
subford
It fits 1994 Ford Trucks. If you have a 1993 then post the Calibration number off the drivers door post and we will tell you what computer to get as this one will not fit a 1993 Ford truck. The number you listed is for a CCD Ignition system and the 1993 truck takes a push-start computer.
1994 F-150 Pickup
Application Data:5.8 Liters and w/M.T. and Federal Emissions; w/I.D. #F4TF-AHA
Units are pre-programmed at the factory.
1994 Ford Trucks
F-250 Pickup
1994 Ford Trucks
F-350 Pickup
Alternate/OEM Part Number(s): F4TF12A650AHA, F4TZ12A650AHA, F4TZ12A650AHB, F6PF12A650ELA, F6PZ12A650ELA
Old Feb 4, 2013 | 08:45 AM
davetrydahl
EEC substitute
First of all I apologize-- the truck was manufactured 3-94. Calibration numbers on the door post are as follows: 4-75A-R00. Under that was the following sequence of letters: F4AE-6E061-LZL. Thanks for the help.
Dave
Old Feb 4, 2013 | 09:38 AM
subford's Avatar
subford
The Ford part number that the Ford dealers go by is F4TZ-12A650-AHA and the drawing or engineering number is F4TF-12A650-AHA that is the number on the part and what auto part stores go by.
Your parts list:
Old Feb 4, 2013 | 11:36 AM
davetrydahl
Thanks very much. This should get me there.
robreynolds
22
Mar 3, 2018 10:01 PM
UnknownCubicle
Dec 1, 2010 02:28 AM
javi2001
Jun 19, 2005 09:54 PM
minexist
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 23, 2003 07:03 AM
